This can be useful if you want to change your grill (as I did) or access foglights etc.
First remove your headlights (see this link for details of headlight removal and bulb replacement) – http://www.fordownersclub.com/forums...howtopic=12391
Summary - Remove 2 bolts at top and bottom of headlight, then remove 2 plastic plugs (circled in yellow)
Disconnect electrical connection using flat head screwdriver in slot.
Disconnect your foglights, if you have them, which can now be easily done with the headlights removed.
Now where the headlights were you can now see the body work joint, Here the bumper is held to the wing by 3 10mm head screw bolts each side. A ratchet with an extension will remove the first bolt. If you have a ratchet with “flexible neck” extension, all 3 can be removed. If not, you may have to remove the plastic wheel arch lining to gain access to the 2 remaining bolts.
The wheel arch has a lining which has two torx t25 screws which fasten into the bumper the rest has several screw type plastic rivets clips use a pozi drive on the center pin(force two fingers up behind the lining between it and the chassis with preferably a finger either side of the clip to put pressure on it) turn this a quarter so it raises the center pin slightly and it should pop out, repeat and remove the lining.
From the wheel arch looking at the bodywork joint you now can easily remove the 2 lower screw bolts.
