Results 41 to 50 of 79
- Jan 2011
- 193
April 30th, 2011 11:48 AM #42You are probably speaking to the wrong person (not your fault).
The "build order" for your vehicle will show "key codes" which can be used to make new keys. The dealer should have this information.
or;
Talk to a qualified locksmith, who, in the alternative can open the rear hatch by picking the lock,which usually is easier to open than a side door.
Ciao!
Uncle Nick.
April 30th, 2011 12:25 PM #43
The hatch door of the Fiesta is ELECTRICAL. Its not mechanical. So its going to be easier to pick the passenger doors which only the driver side has...
April 30th, 2011 12:29 PM #44
I too only see two options to open your FoFi, either you get a duplicate key made using the codes or break the quarter glass.
Trying to get a locksmith to open your car might just damage your lock and eventually you'll have to change all locks (including igition if you don't like to carry a different one for this). Mind you, there is only one key hole for the FoFi hatch, this is by the drivers door only. Also, trying to gain entry via the hatch is not possible as well.
BANNED BANNED BANNED
- Dec 2009
- 607
- Jan 2011
- 155
April 30th, 2011 06:57 PM #46C'mon just break the Glass! I wanna know if its really going to trigger an alarm hehehehe
Seriously, cause Fofi owners have to take "that there will be an alarm when the window is broken" in good faith since there is no perimeter alarm for the Fofi, even a sound when you lock unlock the doors.
April 30th, 2011 07:08 PM #47
^^ Nabasag na nung father ni TS yung rear quarter glass. la nabanggit kung nag-alarm pero hula ko, it did went off.
Fasten your seatbelt! Or else...Driven To Thrill!
- Nov 2010
- 56
April 30th, 2011 09:48 PM #48
- Jul 2003
- 573
May 1st, 2011 12:28 AM #49sa manila, yung mga tow truck na humihila ng parked vehicle sa kalye eh kayang buksan ang locked door para ma-release nila handbrake o kaya mailagay sa neutrel ang oto.
Thi had happened once to my car. Hinila nila papuntang tabi ng Manila City Hall.
May 1st, 2011 12:57 AM #50
Right on the money again Doc!
Given enough time, there is always a way to get in. I tend to favor the door corner technique since steel and even glass has some degree of flexibility. Enough to insert a tool specially made to reach the door unlock lever.
The dealer however needs to protect the reputation of the vehicle and would give one the impression that the ONLY way to get in is to break a window.
Slim Jim or a door shim by the dealer would highlight the weak points ALL vehicles have.
VinFast VF 3
