Results 1 to 7 of 7
- Apr 2010
- 19
August 9th, 2010 03:39 PM #1Hello there fellow Ford vehicle owners,
I have a query po regarding cooling fan of FORD Lynx 2000.
If I switched the aircon on, dapat po ba both cooling fans (cooling fan and aux fan) aandar? or yung isa lang po sa kanila? Hindi po ba sila sabay laging umaandar?
Thanks po and more power...
August 9th, 2010 04:03 PM #2
The left-hand fan (driver's side) goes on according to coolant temperature only. The right-hand fan goes on when the AC turns on or when the load is too great for the main fan. Yes, the AC fan sometimes goes on while the main one stays off. The Lynx's cooling system is efficient enough that sometimes the main fan turns off.
- Apr 2010
- 19
- Apr 2010
- 19
August 11th, 2010 10:00 AM #4I have a question though sir, How will i know if the left hand fan is faulty/not working if it's activated via coolant temperature only? If I switched the A/C on, the R/H fan will be the only one working right if the temperature is not hot enough to trigger the L/H fan?
- Dec 2014
- 1
December 12th, 2014 05:20 AM #6Sir Ask lang po may Ford Lynx ako model 2000 ung Radiator Fan ko ndi nag automatic pinalitan ko na ung Thermo switch ayaw padin pero pag naka Aircon ako umiikot ung isang fan .. ang problema ko po is kapag ndi nag automatic ung Radiator fan ko nasasabugan ako ng Radiator dahil sobrang init .. salamat po sa makakatulong
- Dec 2014
- 6
December 21st, 2014 09:43 PM #7try checking the radiator cap sir. nangyari na rin sakin yan. akala ko sa thermostat may problem. pero nung nagpalit ako ng cap, hindi na umulit.
Did some independent research and decided to go with the white pearl crystal.... para maiba naman. ...
