Page 8 of 8 FirstFirst ... 45678
Results 141 to 157 of 157
    Oct 2004
    Jayo whats your car? XP or F150? okay na sa akin ang 4-5kms....mikey mike wow abot ng 6 ang XP? ang pinaka matipid ko na gas consumption in the last few years sa mga cars ko is 6km/l sa starex pero minsan below 6 din siya....yung iba (which are not SUVs) sa experience ko are below 6km/l....so if the expedition can do 5km/l okay na ako doon.....
    Nov 2003
    pano ba i set yung cruise control???
    When you reach your desired speed (100kph NLEX speed limit in my case) press the "On" then "Set/Accel" buttons on the steering wheel. If cruise control is working, you can now release the gas pedal and your vehicle should hold that speed. When set, you can adjust speed by pressing "set/accel" to speed up or "coast" to slow down, each press of either buttons adjusts your speed by 1mph. Your speed will be maintained 'til you press the "reset" button or when you hit the brakes. Also, there's a minimum speed for it to work, around 50kph (or mph) not sure.
    mao, it's a F150 lariat.
    our f150 lariat consumes more gas than our expedition. maybe it's because mabigat ang 4x4...4x2 lang expe namin eh.
    Oct 2004
    Glennster, ano consumption ng expe mo? mahal daw brakes noon? magkano yung brakes? every kailan pinapalitan? Thanks
    up up up
    Quote Originally Posted by maop99
    mao..we only had our expe for a year so we never had the chance to replace the brakes.
    pinalitan lang namin battery which is 11k.grrrr
    consumption is around 5-6km/liter. we believe umaabot siya ng 6.5 sa highway cruising speed but hindi accurate ang computation namin noong nag baguio kami.
    Regarding safety, the F150 and Expe have been some of the worse sa crash test hehe, so don't be too "secure" just because its big.
    god bless the arabs!
    anyone here knows kung saan maganda magpagawa ng Ford f150 bukod sa kasa, pang ilalim at papacheck ng accuracy ng gauges, thanks
    up up up
    Feb 2005
    Question re f150..
    Just this morning nag lock yung steering wheel then namatay yung makina. Natakot ako kase muntik na akong bumangga sa pader since paliko ako nung nag lock yung manibela... What could cause this? This happened twice already.
    are you sure nag lock muna yung steering wheel bago namatay ang makina?
    o namatay muna ang makina bago mag lock?
    dangerous ang ganyang situation nix...pa check mo na agad.
    Feb 2005
    yep nag lock muna bago mamatay engine.
    honga pa check ko na...gastos na naman...
    Sep 2005
    Ford F150s are quite popular in Iraq among private military contractors.
    hi guys,
    what mods have you done to your truck?for reference lang..thanks
    Aug 2014
    Up ko lang yung thread na ito,. May lumabas ba sa Philippine market na Second Gen na F150? (2005)
    Sent from my SM-G950U using Tapatalk
    Jun 2018
    Quote Originally Posted by timming_gear View Post
    AFAIK sir, wala po. Siguro coming from gray-market.
Ford F150 [Merged]
