Page 486 of 778 FirstFirst ... 386436476482483484485486487488489490496536586 ... LastLast
Results 4,851 to 4,860 of 7777
    Jul 2016
    #4851
    Quote Originally Posted by vin23 View Post
    1. Depends on your location and connections. I inquired on 5 ford dealership and got my unit at ford edsa greenhills. If you want to get the best deal and if you have the time, visit as much dealership as you can. Trust me it is worth it.
    2. So far wala naman issues.
    3. Drove to Baguio via Kennon Road with 7 adults and a trunk full of bags. Walang kahirap hirap especially on manual mode(mine is 3.2 btw). I'm just not sure if may auto blip feature ang everest please correct me if I am wrong but sobrang smooth ng pag downshift niya when you need to go up a steep slope. Dito ko lang din na appreciate yung HSA as our previous vehicles does not have one.
    4. My headlight's aim is still good. Although I am not using the auto feature.
    5. Current Everests are now 2017 models with new sync3 and all black interior. Not sure with 3.2 models. Back then wala talaga sila maibigay na 2017 model for 3.2.
    Sent from my SM-G925F using Tsikot Forums mobile app
    Yes, ala ng 1k PMS, nagbigay Ford PH ng memo, starting 2017. Para ma free up dealer space. Simpleng fluid checks at wheel nut tightening lang naman gagawin dun. Bago naman ilabas din sa dealer yan ichecheck na rin nila yun.
    2. May issues man eh tsambahan lang or minor lang, saka dont worry kaya nga may 3years/100T kms warranty. Covered naman if ever. Ung sa ilaw Ti+ lang affected at baka by this time naman nagawan na nila ng new design ung HL.
    3. 2.2 and 3.2 parehong kayang kaya baguio kahit puno. Yes, may auto-blip ang 6R80 transmission natin, smooth shifting mapa down or upshift yan.
    If you have budget, at for keeps mo na oto, I recommend change oil(kahit no filter) and change axle oil at 3000 kms. Then follow mo nanung tig every 10k ni casa.
    Then change tranny oil at 40T kms, then follow mo na recommended ni casa.
    Remote start kaunting tiis na lang. May inaantay pa ko module galing US.. Hehe..
    Jun 2010
    #4852
    Ano pa update sa features nung sa forscan? Nawala na kasi ako sa counting e..
    Sent from my ASUS_T00J using Tapatalk
    Jul 2016
    #4853
    Quote Originally Posted by gomez_ea2 View Post
    Latest I did was remove all chimes and di iilaw park lights whenever you unlock/lock or open/close a door.
    Quote Originally Posted by Janemar View Post
    Meron option to manually start ng dpf regen?
    Jul 2016
    #4855
    Wala pang DPF ang current everest. But to answer your question, Yes, kaya rin mag manual regen.
    You can also reset transmission and engine adaptation learned values.
    Also, steering wheel angle sensor calibration. This is important lalo na pag lapse na warranty at nag pa wheel alignment ka sa labas. If di sync'd ang 0/straight sa steering sensor at 0/straight sa actual manibela at gulong, youll get all sorts of EPAS related issues. Also program keys..
    Jul 2016
    #4856
    Pinas euro 4 everest/ranger, cat con lang. Same with fortuner and monty. Latest gen crdi systems kaya pasado parin sa euro 4 standards kahit cat con lang puhunan.
    Euro 5 ranger/everest, may dpf na and egt sensor to sense need for regen.
    Euro 6 ranger/everest, may dpf, 02 sensor, add blue and egt sensor na.
    Ah so yun current version wala pa dpf. Thats good for those keeping it longer than 5yrs. I remember meron kasi nag suggest ng dpf regen.
    The other stuff mentioned are good stuff too. Angle sensor failed on a focus 3 yrs ago sa isang forum-they needed a special tool to calibrate it.
    Jun 2008
    #4858
    just sharing the damage for the 20k PMS at Commonwealth last Friday.
    labor - 3038 (less 10% discount)
    oil, filter, flushing, brake cleaner etc - 6668 (shell helix 3215)
    air filter - 3135
    miscellaneous -300
    other charges - 1294 (forgot to ask kung ano ito nakalagay lang sublet and POL)
    total - 14134 plus add VAT
    Quote Originally Posted by gongrhey View Post
    air filter - 3135
    miscellaneous -300
    Helix ultra 5w30? I wonder if its ford specific ie 913D?
    Jul 2016
    #4860
    Eto ung gamit sa casa naka drum.
    Shell Helix Ultra Professional AF 5W-3 | Shell Global
Ford Everest 2015
