Results 1 to 3 of 3
- Jun 2010
- 14
January 27th, 2015 07:36 AM #1Hi Guys,
Ask ko lang po opinion nyo sa case po ng Escape namin.
After po mapa wash over yung kotse, napansin ko nag jejerk sya (na parang kinakapos) bago tuluyang umarangkada, hirap papanik and minsan parang nabibitin unless tapakan ko ng todo yung gas pedal. Nagtry na ako magpalit ng Fuel filter, spark plugs (pero didnt adjust the gap) as well as change oil na rin. Kaya lang andun pa rin yung problem. 19,000+ lang po yung odometer reading ko kasi hindi po sya gamit masyado.
After ko ipacheck sa Shell Times (Las Pinas) ang sabi po is transmission problem na daw at kailangan na palitan. I heared Shell Times got a good reputation in terms of car servicing and I dont have doubts sa skills nila kasi fully equipped sila. Ni read nila sa hand held computer nila yung data and walang nakitang problem, ang di lang daw ma reread is yung mechanical problem. gusto ko lang sana hingin yung opinion ninyo or if meron naka experience ng same sa case ko. Kung hindi naman sa transmission meron pa po kya ako dapat i pa check?
Kasi if sa clutch naman hindi po ba dapat hirap ako mag change ng gears or umarangkada - na parang high rev pa bago umandar? Sa akin naman naandar naman yun lang half way through kakadyot muna sya.
Thank you po!
Rmnl
- Dec 2011
- 3
March 26th, 2015 01:36 PM #2Nung nagpacheck ko nun, walang nakitang problem sa diagnosis, main suspect is the gas, baka marumi or me halong tubig. cleaned gas tank at replaced ATF... works fine now
March 26th, 2015 02:21 PM #3
Traffic!
