Results 31 to 40 of 85
December 14th, 2006 09:03 AM #31
Actually, with the plugs removed, I still wouldn't recommend cranking, even with the plugs out, as this'll just mix more water into the oil. Just use an air hose and dry the sucker out... then air it out to be sure, and replace all the fluids.
Of course, that's if you're lucky and the engine died right away after ingestion. Most of the time, if you have water ingestion while running, you're f****ed.
Like oliver1013 said, and like I've learned from bitter experience... once you're in a flood of appreciable height, forget trying to save the car and driving out. Just stop the engine and try to push the car to safety. It's a pain to dry out electronics, but wet electronics are cheaper to fix than wet electronics AND a broken engine.
Oh, and there are certain cars that you shouldn't drive in even bumper level floods due to the intake position... such as older Lancers, EFI Sentras (carb'd ones have higher air intake tubes) and the Optra. Newer designs like the Mazda3 have intake ducts just above the grille, which means that as long as you can see your headlights above the water, you're kinda safe.
But, best bet? If the water is high enough to touch any part of the body, don't risk it.Last edited by niky; December 14th, 2006 at 09:22 AM.
December 14th, 2006 09:45 AM #33
i like reading the threads here, very educational. just like reading a book in national bookstore for free. keep it up! im learning thanks.
December 14th, 2006 09:46 AM #34
Baka nga naman akala ng mag-asawa its for FORDing water, FORD nga, eh.
December 14th, 2006 12:05 PM #36
Ummm... you don't mix water when you start a fire do you?
Same thing with our engines... it is just a controlled detonation of compressed air + gasoline.
Problem is that when water enters the combustion chamber, it cannot be compressed by the piston like air. Either the engine block cracks due to the pressure or when the connecting rod snaps.
December 14th, 2006 04:09 PM #37
ayos to may bago akong nalaman tungkol sa kotse. ty mga tsikoteers.
December 14th, 2006 04:24 PM #38
December 14th, 2006 04:28 PM #39
It would be better if you opened the air filter housing to check wheter the filter is contaminated. If not, you could probably get away with a restart. If it's wet and you're having doubts - DON'T START! But water will rarely enter an engine that has been shut off prior to fording. Unless the water was really deep or the intake was really low.
Also check the engine oil dipstick and A/T dipstick for contamination.
December 14th, 2006 05:43 PM #40
So guys, if you have to cross a flooded area, any helpful tip on how to do it safely.
The Ten Commandments has been a traditional part of the Holy Week programming on local channels,...
Traffic!
