Results 1 to 2 of 2
- Feb 2009
- 11
September 27th, 2009 05:13 AM #1sir,
nandito po ako sa KSA, plan to buy 96 ford xplorer, any suggestions? the car was imported from USA, odo-106K.
September 27th, 2009 05:29 AM #2
Is that 106,000km or miles? What do you want to know about the Ford Exploder oops Explorer? Get the 4.0 V6 if that is the model you are looking to buy since it has more power. The 5.0 V8 uses the AWD system from the Aerostar minivan, because Ford couldn't figure out a way to make the 4wd system from the other models work on the V8 without being destroyed by the torque of the engine.
high idle RPM at engine start
