Well i guess it depends on who says it.. in other brochures its called sports bar.. thanks for th fyi on the 3rd brake light.. i wish they could let us costumers build our own truck.. i would build a 4x4 xlt with all the electronic gizmos from the wildtrak added and just pay for that..
Hi , is it true that there will be no more xlt 2.2L AT variants to be released? Also is anyone using soft tonneau covers or soft lids here? Thanks
Di kaya natuunan mo yung window switch bro? Better have it checked nalang baka panggalingan pa ng short at sunog.
Sent using Tapatalk 2
Mga Bossing tanong ko lang ilang km dapat ang odometer ng makuha nyo Wildtrak nyo. May unit kasi na binibigay SA ko pero nong check ko kahapon sa warehouse madumi ung unit may putik yong stepboard ska madumi yong bed at gulong pero nakabalot pa sa plastic yong mga upuan. Nagdadalawang isip kasi ako bka nagamit sa test drive yong unit wala susi kasi sunday walang in-charge sa warehouse. Nagtxt yong SA sa kin today 14km na odometer nya ok ba yon? Bank PO po ako with 1% DI lang kailangan ko na daw magdecide today or else ioofer sa iba. TIA
share ko lang:
first 20k km maintenance cost breakdown
1. filter primary - P488.60
2. brake cleaner - P203.57
3. plug - oil drain - P439.60
4. castrol_pej - P5,051.07
5. shop supplies fors - P450
6. labor - P1,950
7. VAT - P1,029.94
total cost = P9,612.80
my first 10k PMS was free.
^9km po akin. Wildtrak 2.2 m/t. Nung araw na kukunin ko na po ung unit, mejo maalikabok po nung tinignan ko at andun pa mga plastic sa upuan. After nuon linagyan na ng tint.
May napansin ako sa wildtrak 3.2 ko, yung rpm needle nya hindi stable when idle and even steady lang apak sa gas. Sumasayaw ang rpm needle. Normal lang po ba toh? Pero hindi naman nag iiba ang sound ng engine.
