Page 54 of 202 FirstFirst ... 44450515253545556575864104154 ... LastLast
Results 1,061 to 1,080 of 7178
    Quote Originally Posted by taraki17a View Post
    i see, could be the case. nataon lang siguro yung paglinis ko ng air filter. try ko advice mo to load mo fuel. thanks.
    Before this happened may choking ba na nangyayari? Is your unit MT or AT?
    May skid plate po ba ang Ranger?
    Sep 2012
    Quote Originally Posted by Djerms View Post
    wala naman ako napansin na choking, mine's mt
    Quote Originally Posted by Rovin99 View Post
    may skid plate, makapal din.
    Metal po ba yun o hard plastic lang?
    Skid plate is metal. Meron bang hard plastic na plate sa ibang brand? I think it should be metal or else mababasag pag plastic sir.
    Aug 2011
    Quote Originally Posted by berong83 View Post
    new here. meron na po bang naka encounter ng ganitong problem sa ranger nyo. bale umilaw ang mga warning control nya sa dashboard at bumagsak lahat ng gauge nya tulad ng speed, rpm, fuel gauge at temperature habang minamaneho ko sya. dinala ko na sya sa kasa yesterday tapos parang my nireset sila sa comp. box. then sabi nila ok na. then kanina nung bumyahe ako lumabas na naman sya. nag aalala na ko. thanks.
    eto 1 week ago
    [IMG][/IMG]
    then kanina
    [IMG][/IMG]
    Naku sir baka lemon yung nakuha nyo. Factory defect. Inmo sa ecu ang problema. Sir, na discharge po ba battery niyo before nangyari to?
    Feb 2013
    Quote Originally Posted by Tj_abs View Post
    D naman po n discharge. 3x ko na dinala sa casa. Iche check daw nila baka sa batery sir.
    Jul 2006
    Quote Originally Posted by Cyferion View Post
    Wow! 4x4 3.2 and 2.2 engine size lang ba difference? Alam ko mas marami pa features ng 3.2 kesa 2.2 ah. Please confirm
    The 3.2 Wildtrak has 6 airbags, ESC and TCS while the 2.2 Wildtrak has dual airbags, no ESC and TCS.
    Nov 2006
    Great! So if the pricing from the earlier page is right. There is really no point getting the 2.2 with less features that is 100k cheaper lang. For 100k you get 4 more airbags and ESC and TCS! Safety above everything!
    what is ESC and TCS?
    The 2.2 wildtrak had two buttons - one on the left was a picture of a car going down (I guess hill descent) the one on the right was a car with swervey lines - I guess this was the traction control. Oh yeah when you use low 4 the traction control shuts off. The traction control is on when on 2h and on the road it was like driving an all wheel vehicle on the winding road of Marcos Hway leading up to Sampaloc Tanay. hitting 90-100kph and I would be stepping on the gas even more when on a curve(probably around 80-90kph) - no fishtailing
    These two features is on the 2.2 manual wildtrak I tested.
    Aug 2011
    I hope ilabas na din ng ford yung bagong everest
    Dear T6 owners. Just want to verify. Ang ranger natin is euro 2 compliant right, so it can take in shell or petron diesels without any problems? Many thanks.
    Aug 2008
    Quote Originally Posted by lancelot97 View Post
    One ford dealership is asking me 10% D.I. (dealer incentive) para mauna daw ako sa pila. That's a whopping 100,000 pesos (plus) para lang magka ranger. I just wonder kung authorized ba ito ng mother company ng ford o kaya ng DTI. I would understand a 3% DI. Pero 10? Grabe naman. MODERATE YOUR GREED PLS...!.
    Hayop sa DI ah! Parang bastos na yang dealer na yan...
    May 2010
    Parang wala ata sa 2.2 XLT yan.
    Jul 2006
    So the difference of the 2.2 and 3.2 Wildtrak are the number of airbags and the engine size only. Justified naman pala price difference. Maybe what edtf means is that both Wildtrak variants have Hill Start Assist, Hill Descent Control, Electronic Stability Control and Traction Control System.
    Nov 2006
    Yes! But I'd pay the price of 100k for more safety anyday! I'm really surprised na may Manual ang Wildtrak ha. This truck will now really blow the Hilux out of the water! :P
    YUP I think too patay yung ibang mga pickup compared to the wildtrack. If I had the money to burn I would get the 3.2li. Just imagine I was planning to just get the 4x4 xl before the test drive but I am now convinced to get the wildtrak 2.2 m/t :D I think the price difference from one model to another is worth it. It now depends on how much you can spend for the truck
    YES that is it!!!!!! - hahahahaha I am not too good with all the technical terms especially when the ride gets to be a bit too technical :D
    I am used to mechanical 4x4 with diff locks and powering your way to the top. Using the wildtrack is a different thing all together
    Jul 2006
    Actually the difference is 70k pesos.
    Jul 2006
    Quote Originally Posted by nicenz View Post
    Guys, what would you recommend? (White) 2.2L. XLT MT or the Wildtrack 2.2L MT? what is the difference when it comes to price?
    Could you guys tell me the features of these 2 trucks?
    Guys, I really need your help. I'm in the stage of deciding. ahah.
    Get the Wildtrak. Hindi ka magsisisi. It has safety features not found in the XLT. It has Hill Start Assist, Hill Descent Control, Electronic Stability Control and Traction Control System. It also has a dual zone fully automatic climate control A/C.
2012 Ford Ranger
