may update sa price ng 3.2 wildtrak?
From feed back sa Ford global....parang June or July launch ng Ford 3.2 ranger Wildtrak...As of now ang padating daw is puro MT na 2.2...this March 2013...and they absolutely hesitant to ask for reservation although ang dami offer ng prospective buyers...kaya "mayabang" yung SA nag-entertain sa akin...medyo as* h*le....hahaha!
...hindi lang "mayabang", they're also taking advantage of the buyers. Asking us 50k just to be sure you'll be given a unit. So, I end up buying another brand eventhough I fall in love with this pickup because of this kind of dealers. Goodbye Ranger... I'll just wait for the new Escape.
sa mga nag loan, pwede ko bang malaman kung magkano dp, monthly, ilang months, freebies niyo and what dealer/bank. Thank you!
mag limp mode or eco mode ba ang ranger natin kung below 80kms nalang ang naiwan to empty? parang humina kasi arrangkada ko kanina, even after loading 11liter which it did not detect and reading stayed at 66km left.
or, was it the air filter element, pina buga ko kasi ng compressed air, hindi advisable bugahan yung air filter to remove excess dirt?
nasa 7k km na unit ko.
Though I think its not normal and should not be the case....
Avoid going below 1/4 of your tank kasi diesel yan so you could've had a case of fuel sloshing inside the tank and taking in air. Try mo kargahan ng mas maraming amount of fuel and see how it goes.
There could also be an air leak in your system. Have it checked, nakakabuysit ang ganyan....
Sounds like:
A sensor(s) alarm, baka may nabasa during engine wash (if u did wash the engine);
Water in Fuel (WIF). It should warn you, but you can check the fuel filter. You can easily just drain the water from it.
Best to have its ECU read. Baka ECU error related problem din.
What are the specs of the few Wildtrak 4x4 units that arrived with the first batch (early 2012)? Automatic 2.2L?
*Cyferion matic lang po ba talaga ang wildtrak? kasi naka pag reserve kami ng manual na wildtrak dito sa cebu. sabi ng SA meron daw manual.
