Page 169 of 202 FirstFirst ... 69119159165166167168169170171172173179 ... LastLast
Results 3,361 to 3,380 of 7178
    Quote Originally Posted by jyri View Post
    Sir Jut, malapit na po kasi ako mag 20k PMS kaya nagcacanvass na ako and it seems you got the best deal.
    Would it be okay if list nyo ano ginawa sa ranger nyo for the 20k PMS?
    Pwede rin po ba mahingi iyong contact/name ng SA nyo sa Ford Makati pati na rin name nyo sabihin ko sana kayo iyong nagrefer if ok lang?
    Thanks in advance.
    I paid 7,220 for an oil change (9L of Castrol Magnatec plus filter) and brake cleaning, along with the usual checks.
    My service advisor was Mark - (0917) 553 0175
    Posted via Tsikot Mobile App
    Dec 2010
    Nakapagtataka ang ranger 2.2 (xlt, manual) aircon. Kahit nasa minimum ka na, ang lamig pa rin lalo na pag gabi. Minsan naman sa araw parang kulang naman sa lamig. Kaya once, inalam ko kung bakit, baka kasi thermostat nya defective, found out na timer control (thru the pcm)ang engagement ng a/c clutch on and off. Parang hindi effective ang ganitong method of control, enconvenient sa atin. Found out thru observation: on a/c knob temp control, minimum setting= a/c engaged for 3 sec only and off(disengaged) for 20 sec. these goes on continually cycling like this. On 1st line=a/c engaged for 4 sec. and off for 15 sec. On line 2=a/c on for 5 sec and off for 10 sec. On line 3=a/c on for 8 sec and off for 8 sec. On maximum setting, a/c on for 15 sec and off for 8 sec. Kaya pala hindi masyado effective ang cooling control ng unit natin. Sana thru thermostat na lang ang control ng a/c.
    Oct 2013
    Thanks sir Jut!
    If I may, pwede ko rin po ba makuha name nyo? Sabihin ko sana na kayo nagrefer if okay lang sa inyo. Kahit pm nyo na lang po sa akin.
    Jan 2012
    wow! that was a long thread. read the entire thing.
    i'm planning to get a diesel fed suv or pick up soon. still trying to decide which to get but the current ranger is definitely in my crosshair.
    Sep 2012
    Saan kaya pumasok tubig? Basa lahat ng under carpet, naabsorb nung white fiberish material. Passenger side both front and back. malinis yung tubig, about half liter natanggal ko sa harap.
    Sep 2010
    Check mo sir aircon drain hose mo,
    Sep 2010
    Normal ba talaga black smoke with particles pag nire rev on stand still? Still on 2000 km reading only thanks
    Dec 2010
    Quote Originally Posted by ketzch11 View Post
    Normal lang yun sir. mawala din yan.
    I don't think so. If i were you i'll bring it back to the dealer so they will be the one to see if it is normal or not. At least magkaron ng record to help you in any warranty claim later.
    Sep 2010
    Sirs, With black smoke lang pag sudden high rev, up to 2.2 rpm, sinubukan ko pag gradual acceleration wala naman black smoke, thanks po jx290 and yebo,
    Dec 2010
    Mga ka forumers, baka gusto nyong palitan ang wildtrak cargo liner nyo at sports bar, I am willing to buy it. You may PM me or post here. Only if you are willing. Thanks. More power to us all! hehehe.
    Mar 2004
    ^^^ How much are you offering?
    Jan 2013
    Quote Originally Posted by JX290 View Post
    Di ka na ma PM. Puno na daw inbox mo. Wildtrak mags and tires meron din. Aside from the bedliner and sportsbar.
    Dec 2010
    Quote Originally Posted by sprikitix View Post
    PM sent sir. Nagdelete na ako. Let's talk.
    Dec 2010
    30K sir.
    Aug 2014
    good day mga sirs. newbie lang po sa tsikot pero lurker na dati pa. i have a 2014 ranger and may nabili ako 4300k 55w HID kit sa abroad. ako na nag DIY sa pag kabit since plug and play lang naman sya. ngayon, gumana naman sya nung nakapatay ang engine nung tinest ko for 5mins. nung in-on ko na, ayaw na nya gumana ulit. binalik ko yung stock bulbs since mabilis lang naman ikabit. ayaw na din nya mag on. ano kaya problema? Thanks in advance.
    Quote Originally Posted by FRanger View Post
    Did you touch the filament itself?
    Chances are, nahawakan mo yung filament which causes premature failure of the bulb.
    Aug 2014
    di nahawakan sir. careful ako kasi sensitive yung halogen at HID bulbs. yung binalik ko lahat sa stock, di na gumana lahat pati wala na yung click sound. checked the fuse, buo lahat. ano kaya?
    how's the socket and the wiring? baka kaya nasunog..?
    uh oh! na-detect ng bcm yang hid mo so ni-off nya ang head lights. gumamit ka ba ng relay? dapat yung oem headlight bulb socket naka-salpak sa relay, at yung relay ang mag-power ng hid. pag rekta lang e yan ang result. pa-reset mo sa casa. pag mabait yung service manager ok lang, pag hindi e bye bye electrical warranty!
    btw, may projectors ba na housing yang hid mo? if wala then, well, good na hindi gumana. baka kasi madami lang magalit sa iyo sa sabog na head lights mo, kaka-glare kasi yan pag hindi naka-projectors.
2012 Ford Ranger
