Page 162 of 202 FirstFirst ... 62112152158159160161162163164165166172 ... LastLast
Results 3,221 to 3,240 of 7178
    Jun 2011
    a/t tranny problem ng ford... nabasa ko na din dati yan...
    buti nalang nag manual ako...
    a/t lang ba ang may ganyan problema?
    Aug 2011
    Quote Originally Posted by kmo View Post
    Spoke to service yesterday, nag software update na sila so the powertrain light is not coming out. Problem, may jerking parin ... Sabi it might be mechanical na ...
    Sir anong model ng ranger to? Wildtrak or xlt? Matic or manual? TIA
    Posted via Tsikot Mobile App
    Oct 2004
    Quote Originally Posted by Tj_abs View Post
    2.2 xlt matic sir. I just spoke to the brother of my friend. He has a 3.2 wildtrak same issue hehe he sold the vehicle na after hehe nawalan ng gana haha! Ummm well paran ganun narin nangyayari sakin
    Service called me up yesterday, "parang ayos na!" Parang??? I hope its fixed na ... Pero having thoughts on selling also
    Aug 2011
    Same model tayo. What is your mileage sir? Mine is 23t km and up to now wala pa naman problem. Maybe isolated ung sa case niyo. I talked to my friend who works at ford wala pa naman major recall ang ranger unless meron silent recall. ( isasabay nila papalitan ung recall parts without informing the customer )
    Aug 2007
    Mine is one month old palang so far wala problem. Sana updated version na yung akin
    Apr 2014
    Same here mag 1 month pa lang wala pa din ako naramdaman problems..
    Hehe, read aussie and thai forums, sama lahat manual and matic, 4x4 o 4x2, 3.2 and 2.2, ford ranger man o mazda bt50. Bwiset!
    Sep 2012
    the unit itself is recommended but not the aftersales I am experiencing
    Sep 2012
    does your unit exhibit this? habang naka apak sa accelarator then honk the horn, may vibration sa accelarator pedal na parang doon naka kabit yung busina...
    Jun 2011
    Kmo go for it... IMO isolated case naman yan... So far sa dami dami ng naka ranger dito isa palang ang nag pa service sa casa...
    Sent from my C2305 using Tsikot Forums mobile app
    Oct 2004
    Nakakawalang gana lang kasi haha but as of now I've decided to use it first and hope its ok na hehe
    Mga sir. Newbie here. Just got my ranger wildtrak a couple of days ago. I'm planning to upgrade my tire to a bigger/fatter one without changing the stock rims. Any advice on what maximum tire size na hindi mgkaroon ng rubbing issues without having to lift the suspension? Thanks in advance!
    Jun 2007
    Quote Originally Posted by poolfreak View Post
    interesado rin ako sa magiging sagot dito. pero mukhang wala pang gumagawa ng ganyan poolfreak. looks like you'll be the first one. puwede mo naman ipa-check sa tire shop na bibilhan mo. trial and error siguro gagawin nilang method. let us know what you'll find sir.
    Jun 2011
    Quote Originally Posted by jeDi13 View Post
    maximum tire height for our ford ranger according to people in fcp is up to 33"...
    yung sakin 275 55r20 no rubbing issues... height ng tires ko 31"
    Jun 2011
    may nakausap ako dati... yung 295 60r20 daw may rubbing issues na? sumasayad sa mud guard...
    solusyon... eh tapyasin ang mudguard...
    Jun 2007
    Based from an online tire size calculator and the info from sir glenn (33" max diameter from FCP), you can upgrade to a wider tire of 285/65/18. If you wanna have a taller tire, you can go for 265/70/18. Both tires have 32.6" diameter. But I doubt if you can actually find those two sizes with the actual tires. There's no available size for those two, well at least from the websites I've searched. 265/60/18 is, somehow, the fattest size that you can get for your stock rims. Looks like there's no other way to go fatter but to upgrade the rim size as well.
    Sir glenn, did you upgrade your shocks when you changed to 20"?
    Jun 2011
    suspension.... no sir.. for now... no mods.. all stock...
    but considering comfort shackles..
    Oct 2004
    Badnews .... After around 65km plus around 40km from roadtest of service, the problem came back ... Drivetrain light appeared and it jerks, and it wont go up mr driveway .... Damn ....
    Aug 2010
    That's really bad news man!
    Hope they find the root cause and fix permanently
    Jun 2007
    Quote Originally Posted by erl919 View Post
    Just pull up the cover one side at a time. Tapos remove screws holding the insulation.
    Let us know kung may kalawang na.
    Ako plan ko to put grease para hindi mag start rust
    Thanks! I did it with your help.
    So far no rust and clean.
2012 Ford Ranger
