Originally Posted by
yebo
Nag limp mode? Nagkaron din ba ng mild shift shock before it happened? How about the CEL umilaw din ba?
Nangyari kasi sa akin may mild shift shock siya after 3500 km odo reading, i was observing kung lumala pa. Then while driving biglang umilaw ang powertrain warning lamp and it could only go up to 3rd gear. I tried turning the engine off and on saka umilaw ang CEL. Pag uwi ko ng bahay and reversing to park the vehicle ang lakas ng shift shock going from D to N and R. I tried all, P, R, N, D and grabe ang shift shock tumatagilid talaga ang pick up. Pero after maybe 5 minutes with the engine off (i got down to check the oil level and look around the engine and tranny for any obvious signs i can report later to the casa) i started the engine again and all the alarms were gone. I test drove it and all was ok. Idadala ko sana sa casa for a check up but meron ako lakad so i took the chance using it. Ok naman na siya, even went off road a bit, using 4H on the gravel and 4L on some mud, then sa hiway went up to 180kph (just to test). Nawala na din yung shift shock, smooth na shifting from P, R, N, D. So di ko na dinala sa casa for diagnostics. 3900km odo nya now.
mazda bt50 3.2 a/t yung sa akin, same engine and tranny as wildtrak 3.2 a/t.
