Page 159 of 202 FirstFirst ... 59109149155156157158159160161162163169 ... LastLast
Results 3,161 to 3,180 of 7178
    Sige try niyo lahat tapos post kayo ng feedback on what happens to your T6 after a year or so. Kung walang masama, then maybe it's worth recommending. 😜
    Personally I have doubts because the 2.2 Puma engine is a fairly modern CRDi and this old-school trick might not work.
    Am also wary of claims that it's smoother or has less smoke etc etc because it can easily be a placebo effect - we see what we think we should see.
    Posted via Tsikot Mobile App
    Jun 2011
    Sige try niyo lahat tapos post kayo ng feedback on what happens to your T6 after a year or so. Kung walang masama, then maybe it's worth recommending. ��
    siguro to really know kung talagang may pagkakaiba.. i need to drive and compare with a fellow t6 owner with mine... and use a sound meter...
    on my part naman... as of now i dont recommend others to do the same... sakin lang hindi kasi ako natatakot masira t6 ko......... and IMO ang dami kong nabasa na recommended ito sa mga diesel engines... maliban sa mga high end diesel... eh IMO hindi naman high end ang engine natin eh... ( i find our engine pa miniscule or maybe it just me..)
    actually sakin po.. nung unang naglagay ako... wala akong napansin na improvements... in my mind "walang pagbabago, maybe bec. its still new pa kasi" then on my 2nd full tank... sabi ko sa sarile ko.. bakit parang patay ang makina? bakit ang smooth tumakbo? pati nginig sa kambyo (MT) nabawasan... but there's no noticeable change in FC and power... sa smoke wala din pagbabago... may kunting usok pa din pag FLOORED.... on my first pms i ask casa if it is normal.. normal naman daw yung smoke...
    pero baka naman po nagkakamali din ako...
    Kung malapit ka sakin bro meetup tayo para matry mo XLT MT na walang 2T and para ako matry ko yung gas-like smoothness ng T6 mo. Taga-Pasig ako if you're interested.
    Jun 2011
    sabi ko nga sir.. baka naman po nagkakamali din ako... or "maybe its just me"
    pero cge po.. taga q.c. lang naman ako... PM Kita pag nagawi ako sa area mo... or kung kayo naman ang magawi sa q.c. pm me din...
    at least malaman natin habang maaga kung placebo effect nga lang yung nararamdaman ko po...
    mamaya pala between 5.30-6pm nasa top 4x4 off road ako..its along Congressional ave.. near luzon
    So I tried putting 2T along with my full tank last night. 200mL 2T from Shell mixed with Unioil diesel.
    No night-and-day difference for me. At first it felt quieter and smoother, but when I drove it again this morning, parang wala naman. Must be a placebo effect.
    Will continue to monitor for any improvements over the course of a week or two. Then in my next fill up try ko uli na wala, in accordance with typical A-B-A methodology.
    Jun 2011
    Sir try nyo 2 straight tank fulls... Sakin kasi between the 1st and 2nd Ko napancin...
    Sent from my C2305 using Tsikot Forums mobile app
    Dec 2010
    So here's my version using 2T. Nawala yung nginig ng makina pag switch off mo. Dati nangingisay lagi. Ito yung pinaka una kung napansin. Pati Mrs ko na hindi alam na hinaluan ko ng 2T yung diesel napansin nya. And then, fuel economy nag improve din. 12.6km/L na. Usually lagi akong 10.6km/L.
    I'm considering buying a ranger... Do you guys (owners) still highly recommed it?
    Oct 2004
    Quote Originally Posted by Glocky View Post
    Looks wise of course. Before my tranny issue, yes hehe
    Just got my unit from the service regarding the tranny problem. Hope its permanently fixed.
    Hi
    My lag po n tlg ung 2.2l matik
    Balak q po kc bumili ng 2.2 ranger matik sa mga review cnsbi my lag dw..gano po to katotoo?
    Quote Originally Posted by Dons30 View Post
    Baka pag hindi ka na nagtext-speak mawala yung lag.
    But seriously, the Ranger 2.2 has severe turbo lag, whether with a manual or automatic transmission. It doesn't have much power below 1.5k rpm, then pulls like a beast from 1.5k-3.5k rpm.
    With an AT though, you don't have to worry too much about the lag because the transmission is smart enough to pick the right gear to get you going.
    Jun 2011
    5ml. To 1 liter... Po... Them give us feedback po... Before and after your 3rd fill-up
    Dec 2010
    So the correct ratio would be 400ml 2T for every full tank, if the ranger has 80 liters full tank capacity and to use the JASO FC rating.
    Will try this!
    Jun 2011
    Quote Originally Posted by JX290 View Post
    Will try this!
    yes sir.. then after your 1st full tank with 2t experiment kayo... bawasan nyo naman... make it 200ml per full tank...
    last time 200ml lang nilagay ko sa full tank.. sa next fill up ko... 400ml naman ilalagay ko..
    Sir Glenn, what brand of 2T po your using or can recommend? I'm using petron diesel with my ranger a/t, ok na din po ba yun 2T ng petron use ko?
    Jun 2011
    Yung Cheapest lang po sa unioil... Every fill up ko dun na din ako bumibile
    Dec 2010
    Yung sa petron ay ang rating JASO FB. Ang dapat daw ay FC.
    Sep 2012
    question lang po sa mga nakapag 30k km pms. magkano po singil ng casa at ano mga ginawa aside sa change engine oil. salamat.
    Dec 2010
    Quote Originally Posted by taraki17a View Post
    Change air filter and fuel filter lang ang additional. Air filter around 600php and air filter around 3k.
2012 Ford Ranger
