Page 157 of 202 FirstFirst ... 57107147153154155156157158159160161167 ... LastLast
Results 3,121 to 3,140 of 7178
    Oct 2009
    Quote Originally Posted by WenG2 View Post
    meron din pala lock sa glove box ng 2.2 WT ko
    here's the 2.2 WT tailgate without key lock
    2.2xlt sakin. Meron lock sa glove box. imageuploadedbytapatalk1398308156.080663.jpg
    Quote Originally Posted by ebmosqueda View Post
    Meron nga hehe ngayon ko lang napansin. Kahit pala XLT meron
    Posted via Tsikot Mobile App
    Unichip, DPChip, or Race Chip for a 2.2 XLT MT?
    I haven't seen a Ranger with a Unichip but with a Montero, gains are about 20%. Also I saw a comparison between a Race Chip and Unichip and mas malaki gains ng Unichip across the entire RPM range.
    Would like to know pros and cons of each option, and what's the best choice for a good boost that will not mess up my engine.
    Dec 2010
    chips are an easy modification to shift more torque and power to lower rev ranges ... (don't expect to get more power and a lower fuel consumption at the same time as some vendors want to make you believe...) consider, that every time you ask for more power there will be higher wear and tear, on engine and drive train components, brakes and tires - that's the physics ...some chip vendor will give a "warranty" wrt engine and drive train damage: they can do this because they still operate the engine in the same performance range designed by manufacturer via the engine map, but closer to the max. threshold.
    Additionally be also aware that more power means more heat the cooling system of the engine has to cope with. While I still believe that most of the overheating issues are caused by lack of coolant in the system a few cases might be also caused by tuning chips: owners are happy about the higher torque when pulling their vehicle up a steep hill ignoring at the same time that the additional heat needs to be exchanged via the same, unmodified cooling system...
    Dec 2010
    Quote Originally Posted by JX290 View Post
    I'd rather my car have a shorter lifespan with more fun than keep it for decades, perpetually short of low-end grunt.
    As long as the car lasts a good 5-10 years with minor mods, I'll be happy. Would you have experience of chipped diesels conking out prematurely?
    I'd rather my car have a shorter lifespan with more fun than keep it for decades, perpetually short of low-end grunt. As long as the car lasts a good 5-10 years with minor mods, I'll be happy. Would you have experience of chipped diesels conking out prematurely? Posted via Tsikot Mobile App
    Well, there have been stories. PM Jag.
    No Signature
    Dec 2010
    Is your ranger having issues with low end power?
    I have a chip on my Sta Fe before for a year. But then 1 day the engine suddenly fails and went into limp mode.
    It was an injector problem and that was due to the chip. It just tricks the ecu about the rail pressure. The injector
    can't handle no more.
    It's not an issue per se, it's just that the turbo lag is pretty significant. A 2.2 turbo (that isn't made by Hyundai or the Germans) relies too much on boost and thus is pretty lifeless below 1500 rpm.
    With a chip, I expect an increase in power across the rev range that will be most felt in lower rpms.
    What did you do next to repair your Sta. Fe?
    Aug 2007
    Friend of mine does it for 2.2 and 3.2.
    Brand is upsolute
    Mar 2004
    ^^^ Most recent pickups don't have tailgate locks.
    Quote Originally Posted by erl919 View Post
    No lock on the tailgate? Seriously!? Wow that is bad. So you can't secure the bed even if you have a locking rolling cover
    Ford talaga!!!!
    The roller cover installer will install 2 dead bolts on the inside of the tail gate that will allow you to lock the tail gate from the inside. The dead bolt can only be accessed when the roler cover is opened. It is also spring loaded so pushing the tail gate closed automatically locks the tail gate.
    Apr 2014
    http://s1318.photobucket.com/user/Gi...xtfzu.jpg.html
    Wala po ba tayo handle para sa driver side.. na miss ko yung sa fortuner ko..
    Aug 2007
    Quote Originally Posted by dondiemcp View Post
    Wala! Nagtitipid ang Ford hahaha
    Apr 2014
    Wala po ba nabibili na aftermarket? Or Stock ng righthand drive na ranger?
    Aug 2007
    Baka meron. Pag may nakita ka tell us kasi ako din gusto ko. Palagi nalang steering wheel ako humahawak pag sakay
    Apr 2014
    Hahaha same tayo sir.. saka isa pa na miss ko sa fort ko yung ilaw ng ignition switch.. hirap mag susi pag madilim na.. need pa buksan ang ilaw sa ceiling.
    Nov 2006
    Sirs,
    question on XL 4x4. Ano ang pinag kaiba nya saga XLT bukod sa 4x4? Like engine horse power and interior? And haba din ba pila sa XL 4x4?
    Thanks in advance!
    Aug 2007
    XL 125hp 330Nm
    XLT 150hp 375Nm
    3.2L 200hp 470Nm
2012 Ford Ranger
