Page 132 of 202 FirstFirst ... 3282122128129130131132133134135136142182 ... LastLast
Results 2,621 to 2,640 of 7178
    Sep 2012
    last year i got my ranger xlt cash with no d.i. today i finally completed my 10 k maintenance for free parts and labor ( after having a little hassle) 😊🎉😊🎉
    Sent from my iPhone using Tapatalk - now Free
    Quote Originally Posted by ruz View Post
    Hope you could sare which casa and what hassle so we can watch out. Ty
    Sent from my GT-I9082 using Tapatalk 2
    Sep 2012
    Quote Originally Posted by Djerms View Post
    its in ford commonwealth. its just a little misunderstanding with their staff. but the issue has been resolved by their management. thanks to them.
    May 2013
    Thanks bro.
    May nakapag 20tkms pms na ba sa atin? How much inabot?
    Sep 2012
    Thanks bro.
    not really sure. hanggang 10k lang kc ang libre sa akin
    Mar 2007
    sorry guys ot. share ko lang. hindi ako sure kung may nakatama sa roof ng t6 ko o nailabas ko sa dealer na meron na pala yun. meron 2 dent kasi sa roof. sabi ng iba imposible naman kung tinamaan ng volley ball which is light weight at ng bounce pa. or kung let say sa carwash. impossible din sa roof magka dent samantala all sides eh walang dent. ano kaya nangyari?
    Quote Originally Posted by kng200 View Post
    Malamang sa casa yan. May paint chip ako from casa nakita ko nalang after delivery. Tapos last week nagpa pms kami napansin ko may malaking gasgas. Hay nako.
    Mar 2007
    kaya nga nakakapanghinayang lang. yes true hindi kita kasi nasa roof ang dent pero hindi naman kaya gawin PDR na hindi kinakalas yung ceiling. parang mas ok na yung dent nasa sides madali ang acces para ma PDR. balak ko nalang hayaan na muna. 4-5 years ko din balak gamitin t6 ko. 2k palang odometer reading, napakabata para magkadent na.
    Bat ang titipid ng Ranger niyo..10.3 km/L pa rin ako mostly provincial highway. Hay. ⛽️
    Usually napapatipid ko naman ang sasakyan pero for some reason I can't go past 10 km/L with my Ranger.
    Naubusan na nga ko ng daan, di pa rin tipid. Hehe.
    Dec 2010
    Depende kung gaano ka kabilis magpatakbo and how you drive your ranger.
    Jut,
    Actually tumipid ranger ko after the 4k odo. Nagpalit na din kadi ako and shifted to liquimoly oil. Ilan naba odo reading nung sayo?
    Remember its better to be in a lower gear than in a higher gear tapos ibabalik mo din sa lower gear madalas. Ako kahit highway, pag madami sasakyan at alam ko preno ako, I avoid 6th gear. Basta maintai rpm lang.
    Ok lang yan...wag ka susugod diyan sa dagat!
    Jut,
    4300 na ngayon. Last full tank ko was 3988 km. reading ngayon is 10.3 km/L but I think nasa 9-something lang kasi lagpas half tank na ko tapos di pa 400 km nabyahe ko. Babyahe ako pabalik ng Legazpi from Sorsogon later, tingnan ko kung tataas.
    First turbo car ko to so di ko sure baka iba diskarte with a turbo. With the ranger the turbo kicks in around 1.5k rpm so whenever i need to overtake i try not to go below that para hindi masyado madiin sa accelerator. But when cruising kahit below 1.5k basta minimal apak.
    Main problem is tricycles/buses/jeeps kasi kung 100 takbo ko tapos may tricycle edi pepreno ako then accelerate na naman pagkatapos..
    Naubusan na ng daan, dagat naman..
    Minsan kasi bro mas matipid to maintain 2krpm by going above that so in between braking or shifting you wont dip down thelow rev tapos waste fuel para umanga ulit.
    Dec 2012
    I see... Driving habit ko kasi is lagi naka maintain sa 1rpm-1.5rpm city driving para hindi ko naapakan ng madiin. sabi nga saakin, parang may NANA daw ang paa ko. Also masama po ba na iniintay ko ma empty ung fuel tank ko? kasi last time bago ako magpa full tank 30km n lng pede nya takbuhin bago ako nagpa gas. And normal lang ba na umingay ng konti ung engine after ng 10k PMS? Btw, full tank ko umaabot ng 1month naka pag balikan na ko from Cabanatuan City to Quezon Ave. . 12km-20 a day siguro since may pwesto ako sa mall...
    diesel and gasoline engines are at their best efficiency when running at its highest torque output. so if the torque curve is highest at 1500-2500 rpm then that is where it is most efficient. running at below 1500 rpm is less efficient.
    crdi pumps use fuel to cool the pump. there is always excess fuel that goes back to the tank, and the tank acts a cooling heat exchanger. if there is less fuel in the tank there is also less cooling. so yes, masama sa engine yung konti na lang fuel sa tank. paminsan-minsan ok lang, like if hindi talaga maiwasan. but as all casas advice, it is better not to let the fuel tank go below 1/4.
    just wanted to share what i know. i'm still wishing to buy one (or the new eve).
    May 2013
    Sa amin nga, nasa 8k na ang odo pero nasa 10.3km/L pa rin. Baka kailangan i reset, hahahaha.
    OT:
    Sa legazpi boulevard ba yan na pic?
    Quote Originally Posted by engrjuvz View Post
    OT:
    Drive it hard!
    Aug 2003
    Guys rule number 1 sa mga common rail e fill up once you reach the 1/4 level. The dirt trapped in the bottom of the tank will be abrasive for the high pressure compnents.
    Follow-up ko lang.. May nakapag egr blank na ba ng T6 dito? Looks like sa Australia they are not getting any CEL..
    Mar 2004
    Quote Originally Posted by ek2jayvee View Post
    This old, outdated advice keeps on being given, don't you think the hose inside the fuel tank gets fuel from the bottom of the tank? How else would it be able to get fuel? Does it sip from the top part of the fuel tank? Then there's also the fuel filter, it will get clogged long before dirt can go to the engine.
2012 Ford Ranger
