Page 1 of 2 12 LastLast
Results 1 to 20 of 35
    Aug 2003
    What's with can openers today(the ones with a knob), andaling masira i've already bought the more expensive ones like Swing Away, Sunnex, they don't last more than a few months. Usually yung gears ang nasisira, and the cutter just won't bite into cans any more.
    Nasubukan ko na rin yung P38/P51 "military type" can opener; at first use, i already noticed some edges bending; i don't expect it last very long.
    i don't ever remember having this problem in the past; minsan yung maramihang lutuan pa, we'd go through dozens of cans with no problems.
    Can anyone recommend a good one? We're using an el cheapo can opener right now, 100+ pesos lang, It's doing a better job than the two i mentioned, but i don't think it will last long.
    tia
    Mar 2004
    Yeah, I remember when I was growing up, we only had one can opener (the simple one with a butterfly type winder and a bottle cap opener). That can opener lasted until I graduated from college.
    But now, as you said, even the expensive types don't last long. It's as if tumibay yung bakal ng mga delata. Or talagang masagwa na ang quality ng can opener.
    Anyway, I've had best luck with a side-opening can opener. The current one I'm using is Chef's Choice.
    http://scene7.targetimg1.com/is/imag...id=480&hei=480
    Two years old and still going strong.
    Apr 2012
    Yunf can opener namin this past month lang 3 nasira. Nawala kasi ug can opener namin na matagal na.
    dati kasi all metal, ngayon plastic yung pinaka-bearing nya kaya lumuluwag yung gear. wala ka na makikita na all metal unless you for the table top model, yung may clamp sa table tapos may crank sa taas. gusto ko na nga iuwi yung nasa galley nitong rig hehehe!
    Lol i had this issue too. The oxo and ikea brands are good.
    Jan 2009
    The same goes ba with those electric can openers?
    Jul 2013
    Ganyan din problema ko dati.
    Yung can opener ko ngayon ilang taon na, okay pa din.
    Yung design niya ay yung most common pero all metal siya. Ito dapat ang una mong hanapin. Pag may plastic part, dehado ka na.
    Second kong sinigurado ay solid ang pagkakagawa at wala masyadong play sa rotating parts.
    Then third, for its size, mejo mabigat sya. Yung weight yung proxy ko for metal strength. Not sure if it is accurate but looks like it worked.
    Of course kahit na common design sya tapos ang liit tingnan, mejo mahal siya. Another sign na mejo may quality.
    Feb 2009
    Old reliable as the M-1911 pistol:
    http://www.georgia-outfitters.com/im...sshelbyp38.jpg
    The P-38 can opener for the C rations before MRE's
    Oct 2013
    P10-20 lang ang el-chepo can opener sa palengke
    Feb 2009
    This can opener will last for generations
    http://ecx.images-amazon.com/images/...0,190,246_.jpg
    Sep 2011
    Lol tibay nito. Inuwi ng tatay ko galing saudi nung grade1 ako.37 nako gamit pa namin pag umuuwi ako probinsya. Tanda ko pa hirap ako gamitin noon kasi mabigat. Itataas mo kasi at ibabagsak para tamaan yung gilid ng can.
    Ito nasubukan mo na?
    Aug 2003
    Dunno if i got the cheap stuff, but the notch that hooks onto the rim of the can got bent at my first attempt.
    Aug 2003
    Quote Originally Posted by carofsteel View Post
    Parang mahirap linisin to sir...but i bet it's very popular with kids. So kung gusto niyong utuin, este, iencourage yung mga bata na tumulong.... ^_^
    i bought this last month, let's see how it does:
    OXO Good Grips Locking Can Opener with Lid Catch
    the ecko classic can openers of old, worked very well even after years of use..
    the new ones of the same brand may look like the old one, but i believe the quality of the metal has changed..
    the new ones don't work as smoothly as the old..
    this is what we have in the galley that i said i want to bring home hehehe!
    This is what we have, I think its more than a year old. I remember before having this eh we went through a lot of can opener that only last a couple of months. Eurochef ang tatak.
    sa akin, walang matinong can opener na may de roskas.... sooner or later, masisira at masisira pa din yan.
    for me, ang pinakamatino is yung manual..... punas at hasa lang ang katapat.
    May 2010
    San mo nabili sir?
    Surprised to see these thread. Matagal na ko kinukulit ng nanay ko to replace our can opener, which is relatively new.. Naiinis na yata siya na wala na kameng tumagal na can opener.. Pinaghahanap pa nga ako ng mga made in germany daw. Any recommendations?
    Mar 2013
    and i thought na napakamalas ko sa can opener dahil walang tumatagal samantalang yung can opener ng ermats ko ilang dekada na ata. puro mahinang klase na pala nabibili ngayon.
matinong can opener
