Page 1 of 6 12345 ... LastLast
Results 1 to 20 of 131
    McDonald's® Chicken McNuggets™
    SPECIAL TOOLS: Deep fryer
    Ingredients:
    vegetable oil (in fryer)
    1 egg
    1 cup water
    2/3 cup all-purpose flour
    1/3 cup tempura mix (or 1/3 cup flour for a total of 1 cup if tempura mix is unavailable)
    2 teaspoons salt
    1 teaspoon onion powder
    1/2 teaspoon Accent®
    1/4 teaspoon pepper
    1/8 teaspoon garlic powder
    4 chicken breast filets, each cut into 6-7 bite sized pieces.
    Cooking your McNuggets™
    1. Beat the egg and then combine it with 1 cup water in a small, shallow bowl. Stir.
    2. Combine the flour, salt, Accent®, pepper, onion powder and garlic powder in a one gallon size zip lock bag.
    3. Pound each of the breast filets with a mallet until about 1/4-inch thick. Trim each breast filet into bite sized pieces.
    4. Coat each piece with the flour mixture by shaking in the zip lock bag.
    5. Remove and dredge each nugget in the egg mixture, coating well. Then return each nugget to the flour/seasoning mixture. Shake to coat. Put nuggets, bag and all,
    in the freezer for at least an hour. Cover and refrigerate remaining egg mixture.
    6. After freezing, repeat the "coating" process.
    7. Preheat oven and large cookie sheet to 375°
    8. Deep fry the chicken McNuggets™ at 375° for 10-12 minutes or until light brown and crispy. (cook only about 9 at a time.)
    9. Drain on paper towels 3-5 minutes.
    10. Place deep-fried nuggets on preheated cookie sheet in oven and bake another 5-7 minutes.
    11. Serve with your favorite McDonald's dipping sauce.
    | Back to the McMenu |
    Egg McMuffin®
    This is a PER sandwich recipe:
    Ingredients:
    1 large grade A egg
    1 english muffin
    butter, REAL butter
    1 slice American cheese (real...not processed cheese food)
    1 slice Canadian bacon
    1 "12x12" sheet of wax paper
    Non Stick Cooking Spray
    SPECIAL TOOLS:
    You need an egg ring. Find one at you're favorite cooking specialty store.
    COOKING your Egg McMuffin:
    1- Pre-heat an electric griddle to 275 degrees. Toast your english muffin by laying both sides face down on the griddle and applying pressure. This takes about 1 to 1.5 minutes. (they
    should be medium brown) Set aside.
    2- Lay your egg ring on the pre-heated grill. Spray with Pam to prevent sticking. Crack the egg and pour into egg ring on the grill. Poke the yolk with a sharp instrument so it flows.
    3- Butter both toasted halves of the english muffin liberally with melted butter. Put a slice of American cheese on the bottom half.
    4- About 2 1/2 minutes after you started cooking the egg, the whites should firm up, and the yolk should still be a bit "liquidy". Carefully remove the ring, leaving the egg on the griddle.
    (you may have to "slice" around the edges if it sticks)
    5- Very carefully turn the egg over, and lay one slice of Canadian bacon on the griddle.
    6- After about 30-45 seconds, "flip" the Canadian bacon, and remove the egg, placing it on the bottom half (cheesed half) of the english muffin.
    7- Put the Canadian bacon on top, and cover with the top of the english muffin.
    8- Wrap in pre-cut wax paper just like the hambugrer recipes. Let stand 5 minutes, then microwave 12 second on high, and eat.
    Filet~O-Fish®
    You'll need a DEEP-FRYER for this one. (this is a per-serving recipe. Multiply everything by each serving needed.) Fish patty can also be baked per package directions.
    1 Van de Camps frozen breaded whitefish patty*
    1 small, regular hamburger bun
    1 Tablespoon prepared tartar sauce
    1/2 slice real American cheese
    dash salt
    1 12"x12" sheet of waxed paper (to wrap)
    **use any square whitefish patty not extra crisp, like Mrs. Pauls, or even the store brand.
    (as with the burgers, pre-heat your oven to warm. This is your warming "bin".)
    Pre-heat you fryer to 375-400 degrees. After its ready, cook fish 3-5 minutes until done.(do NOT thaw first.) Remove and add a dash of salt.
    In the old days, the bun was quick warmed using a steamer. We'll use the microwave. Microwave the bun about 10 seconds, until hot and steamy. (Do NOT toast the bun) Add about 1
    Tablespoon of prepared tartar sauce to crown side of the bun. Place the cooked fish filet on top, add 1/2 slice american cheese centered on the fish, and add heel of the bun. Wrap in a
    12"x12" sheet of waxed paper and warm in oven's lowest setting for 8-10 minutes. Dig into a fabulous Filet~0-Fish!
    ****************ONCE AGAIN**************** An alternate "Q-ing" method would be to wrap the sandwich tightly in wax paper, let sit for 5 minutes, and microwave on high
    for 15 seconds (while still wrapped.) In fact, you can use this method on ALL of the burger recipes on this site, with the exception of the McD.L.T. ("Q-ing" was a McDonald's term for
    helping the flavors to meld via mechanical means; ie heatlamp or microwave.)
    McDonald's® Famous French Fries
    Special Tools
    Deep fryer
    French Fry Cutter
    (or patience for cutting potatoes)
    Ingredients:
    2 large Idaho russett potatoes
    1/4 cup sugar
    2 Tablespoons corn syrup
    1½-2 cups hot water
    6 cups Crisco® shortening
    1/4 cup beef lard (or save the fat from previously cooked burgers)
    salt
    Preparing your french fries
    Peel the potatoes. In a large mixing bowl, combine sugar, corn syrup, and hot water. Make sure the sugar is dissolved. Using a french fry slicer, cut the peeled
    potatoes into shoestrings. The potatoes should be 1/4" x 1/4" in thickness, and about 4" to 6" long. (You can do this with a knife, but it is alot of work)
    Place the shoestringed potatoes into the bowl of sugar-water, and refrigerate. Let them soak about 30 minutes.
    While they're soaking, pack the shortening into the deep fryer. Crank up the temperature to "full". The shortening has to pre-heat for a very long time. It will
    eventually liquify. After it has liquified and is at least 375°, drain the potatoes and dump them into the fryer. (be careful, it will be ferocious)
    After 1 to 1½ minutes, remove the potatoes and place them on a paper towel lined plate. Let them cool 8 to 10 minutes in the refrigerator.
    While they're cooling, add the lard or beef drippings to the hot Crisco®. Again, crank the temperature to full. Stir in the lard as it melts into the oil. It will blend in.
    After the deep fryer is reheated to 375°-400°, add the potatoes and deep fry again. This time for 5-7 minutes until golden brown. Remove and place in a large bowl.
    Sprinkle generously with salt, then "toss" the fries to mix the salt evenly. ( I suggest about 1 teaspoon of salt, maybe slightly more)
    Serve hot, serve immediately, and enjoy! Depending upon the size of the potatoes, this recipe make about 2 medium sized fries.
    Special Notes
    Note¹***** If you want more fries, double the recipe---but DON'T double the cooking oil. Just cook them in shifts, adding about 1/4 cup more Crisco® and 1
    tablespoon lard for the second batch.
    Note²***** If cooking for a minute or so, removing, and returning the fries to the oil seems like a pain in the ass, that's because it is. But it is an important
    "blanching" step required for that great taste.
    Note³***** For an easier clone of McDonald's french fries, you can use the frozen, pre-cut Ore-Ida® shoestring potatoes. Just cook them in the same combo of
    Crisco® and lard, skipping the "blanching" process. Cook them while still frozen for 6-10 minutes (depending upon the amount) until golden brown. They're good,
    but not nearly as accurate in taste and texture as the fresh recipe.
    THE REGULAR HAMBURGER
    The McDonald's® regular hamburger is the one that got it all started in 1948. It's as basic as can be...yet the ones they serve today don't even taste CLOSE! Make em exactly as I
    instruct, and you can enjoy that long-lost flavor once again.
    (In the mid 80's, McDonald's® began cooking both sides of the meat at the same time, This was to cut cooking time in half. But it also forever changed the flavor of the orginal
    hamburgers---ALL of them!)
    Ray Kroc discovered the McDonald brother's San Bernardino, Cal. restaurant in 1954 while selling mutli-mixers. (shake machines) He was so
    impressed with their methods, he struck up a franchise deal, and in 1955 opened his first store in De Plaines Illinois. Oh, and he went on to earn
    multi-millions.
    (FYI.... In 1952, two years BEFORE Ray Kroc stumbled upon McDonald's, Burger King's founder Keith Cramer got his idea for a burger "joint"
    after visiting with the legendary McDonald bros.) For a more detailed history, visit the McDonald's® Story page.
    "Ten Regs please"..."Ten Regs, thankyou"
    (An old production call for ten burgers)
    McDonalds® regular Hamburger ingedients:
    1 -Pound ground chuck (80% lean)
    10 -Small hamburger buns
    10 -Hamburger dill slices
    10 -teaspoons dried, chopped onion
    McDonald's® Hamburger Seasoning
    Mustard, Ketchup ....and ..... waxed paper
    The Hamburger Seasoning:
    4 Tablespoons salt
    2 Tablespoons Accent (msg)
    1 teaspoon ground black pepper
    1/4 teaspoon onion powder
    Mix all ingredients well in a spice shaker with big
    enough holes to allow pepper to flow. Makes about 3 ounces. Use on ALL McDonald's hamburgers. (unless you're allergic to msg, then just use
    salt and pepper.)
    The Beef Patties:
    Divide 1 lb of beef into 10 equal sized balls. Form a patty out of each ball about 4 inches in diameter and 1/4 inch thick. Do this on waxed paper.
    Now freeze the patties for at least an hour. (this keeps them from falling apart when you grill 'em)
    Obviously you'll do this in advance of "burger time". It is pretty tough to make patties this small, so if you come up with 9 patties, I'll forgive you.
    For PERFECT McDonald's® Hamburger Patties click [ HERE! ]
    The Onions:
    Put the dried onions in a container, oh..like Tupperware...and add water. Water should be a few inches over the top of the onions. (better to have too
    much water than not enough) Cover, and refrigerate about 1/2 hour. Drain the liquid, and BAM...you have McDonald's little baby onions.
    Cover again and refrigerate until 'burger time".
    The Pickles:
    McDonald's® pickle slices are unique in flavor, very sour dills. The only product I know of that comes close to the distinctive flavor is HEINZ
    Genuine Dills. (original sour dill.) But they don't come in slices, so slice your own VERY thin. I can't do it very well with a knife, so I use a K-tel
    "dial-a-slice" home vegetable slicer. ALSO....Vlasic "original" dills have that tart flavor. Make sure they're not "kosher" dills. Wal-Mart®
    carries Vlasic ORIGINAL dills, and you have to slice those too. (****note, these pickles are pretty small, so slice at an angle....you'll get bigger dill
    chips.) USE THESE PICKLES ON ALL McDONALD'S® HAMBURGERS!
    The Buns:
    Use the small, plain cheapo store brand hamburger buns. You know, they come 8 or 12 in a pack. Usually about 59 to 69 cents for a pack of 8.
    (You'll want to separate the tops, or "crowns" from the bottoms, or "heels"...as most likely they'll be connected slightly on one edge.) When it's
    "burger time", you'll be toasting the buns. Those instructions are coming up.
    WalMart® sells a great product for regular buns---Great Value™ brand "jumbo" hamburger buns. They're almost exactly like McDonald's® buns
    and a little bigger than the other hamburger buns available at your supermarket.
    ONE MORE THING: Before you cook these marvelous hamburgers, pre-cut 10 12"x12" sheets of waxed paper. You'll need them to wrap the
    burgers.
    Cooking your Hamburgers!
    Pre-heat your oven to warm..its lowest level, this is for later.You're going to need two electric griddles . One to grill the meat, the other to toast the
    buns. Pre-heat the meat griddle to 375-400°, and the bun griddle to about 350°.
    (this recipe has you cooking four at a time)
    ***note***before starting, make sure to have all of your condiments READY! (because this all happens very fast)
    #1 -Toast the crowns of 4 buns (tops) Do this by laying them face down on the griddle closely together. Put a dutch oven (pot) bottom side down directly
    on top of the buns.(open side facing up) This is only to apply hands-free pressure to the buns so they will toast evenly. (Don't use anything TOO heavy
    like cast iron. You'll smash the buns.)
    #2 -Lay the frozen patties on the other grill. After about 20 seconds, "sear" them by applying even pressure with the back of a metal spatula, and
    pushing down on the front with your free hand. (careful not to burn your fingers.) Do this only for about 2 seconds...you should hear them sizzle louder
    while you "sear" them. After searing them, sprinkle generously with McDonald's burger seasoning.
    #3 -At this point, your buns are nearly done. They will have an even tan color when finished. Remove them, and repeat the the "bun toasting" process
    with the heels. (bottoms)
    #4 -After about one minute since searing the patties, turn them over. Careful, don't tear the side you seared. Add another dash of Seasoning and about a
    teaspoon of your prepared onions. (Don't be anal and use a measuring spoon...no time...just two fingers and a thumb full.)
    #5 -Now quickly dress your buns. (crown, or top side) Mustard first....five "kisses" the diameter of a pencil evenly spaced in a circle about a half inch
    from the edge.
    Then the Ketchup, (use Hunt's if you can) five squirts the size of a nickle..in the pattern found on dice. Place the pickle in the middle.
    #6 -By the time you finish that, the meat will be done. (about 1 minute or 1:10 after turning) Remove the meat and tilt to the side to allow excess fat to
    drain off. Use your free hand to hold down the onions. Place patties onion side up on the dressed crown, top with toasted heels. (the burger will be
    upside-down)
    #7 -Lay one finished hamburger, still upside-down, in the center of your pre-cut waxed paper. Wrap the paper around the burger tightly. It should
    resemble a very oblong tube with two open ends, and the burger in the middle. Then wrap the open ends underneath the bottom of the burger so it is
    enclosed tightly.
    #8 -Place wrapped hamburger in your pre-heated oven. (remember...oven is just barely on warm) Keep 'em in there about 8-10 minutes.**** Hey!
    That's enough time to cook another batch. (if you do cook another batch while these are "aging properly", scrape the black stuff and burnt onions to
    the side before beginning.)
    ****PLEASE NOTE! Some ovens get too hot even on low, and this may dry out your burger. If they seem dry, next time wrap them tightly and let them
    sit about 5 minutes. Then ZAP 'em for 15 seconds (one at a time) in the microwave. This will complete the "Q-ing" process without over microwaving
    them like they do now. In fact, they almost taste better this way.
    #9 -ENJOY!! This is how they used to be. This is how they were MEANT to be.
    (You might consider toasting your buns first, at least the crowns, to give you extra time to dress them.)
    McChicken® Ingredients
    SPECIAL TOOLS: Deep fryer; meat mallet
    INGREDIENTS:
    1 egg
    1 cup water
    1/3 cup tempura mix
    2 teaspoons salt
    1/4 teaspoon pepper
    4 sesame seed hamburger buns
    1 cup chopped iceberg lettuce
    McChicken® sauce:
    1/4 cup mayonnaise
    1/16 teaspoon onion powder
    Stir together well, refrigerate until needed.
    Preparing your McChicken® Sandwich
    2. Combine the flour, salt, pepper, Accent®, onion powder and garlic powder in a one gallon size zip lock bag.
    3. Pound each of the breast filets with a mallet until about 1/4-inch thick. Trim each breast filet until it is round.
    4. Coat each filet with the flour mixture by shaking in the zip lock bag.
    5. Remove and dredge each filet in the egg mixture, coating well. Then return each filet to the flour/seasoning mixture. Shake to coat. Put filets, bag and all, in the freezer for at least an
    7. Deep fry the chicken filets at 375° for 10-12 minutes or until light brown and crispy.
    8. As the chicken is frying, toast the buns using the standard method described in cooking regular hamburgers.
    9. On the crown side of the bun, apply 1 tablespoon of mayonnaise mixture, followed by 1/4 cup chopped iceberg lettuce. Then top with the cooked chicken patty, and the heel of the
    bun.
    10. Wrap tightly in a 12x16 piece of waxed paper, and let stand 6-8 minutes.
    11. Microwave on high, individually, for 15 seconds and serve.
    Personal suggestion: CHEESE IT! With real American cheese, one slice, between the patty and the heel.
    Top Secret Recipes version of McDonald's Sweet & Sour Dipping Sauce by Todd Wilbur
    This is a clone of one of the sauces that you can get with your order of McNuggets at the world's largest hamburger outlet. Now, instead of hoarding those little green packs from the fast food chain, you can make up a batch of your own to use as a dip for store-bought nuggets, chicken fingers, fried shrimp, tempura or as a sauce for a sweet and sour dish that includes pineapple, bell pepper, onion, and sautéed chicken or pork. It's a simple recipe that requires a food processor or a blender, and the sauce will keep well for some time in the fridge.
    1/4 cup peach preserves
    1/4 cup apricot preserves
    2 tablespoons light corn syrup
    5 teaspoons white vinegar
    1 1/2 teaspoons corn starch
    1/2 teaspoon soy sauce
    1/2 teaspoon yellow mustard
    1/4 teaspoon salt
    2 tablespoons water
    1. Combine all ingredients except the water in a food processor or a blender and puree until the mixture is smooth.
    2. Pour mixture into a small saucepan over medium heat. Add water, stir, and bring mixture to a boil. Allow it to boil for five minutes, stirring often. When the sauce has thickened, remove it from the heat and let it cool. Store sauce in a covered container in the refrigerator. (http://www.topsecretrecipes.com)
    Makes about 3/4 cup.
    McDonald's® ORIGINAL Milkshakes!
    The milkshakes were changed in the early 80's to reduce the fat content and calories. These McDonald's shakes are how they tasted from the 50's
    through the 70's. Back then the straw would sometimes collapse because the shakes were so thick. ENJOY!
    McDonald's Milkshakes
    SPECIAL TOOLS:
    I suggest getting an Hamilton Beach DRINK-MASTER. It is a consumer version of the multi-mixer's Ray Kroc used to sell to the McDonald brothers.
    (or... a blender works O.K.)
    Vanilla Shake
    2 cups vanilla ice cream
    1 cup whole milk
    1/4 cup half & half
    3 tablespoons sugar
    1/8 teaspoon vanilla extract
    Chocolate Shake
    1 cup whole milk
    1/4 cup half & half
    2½ tablespoons chocolate flavor Nestle Quik Powder
    Strawberry Shake
    1 cup whole milk
    1/4 cup half & half
    3 tablespoons strawberry flavor Nestle Quik Powder
    Shamrock™ Shake
    1 cup milk
    1/4 cup half and half
    1/4 teaspoon MINT extract (not peppermint)
    8 drops green food coloring
    1. Combine half of the ingredients for the shake flavor of your choice in a the silver cup that comes in the DRINKMASTER, and mix on high speed until
    smooth. Pour into a cup. Repeat for shake #2. Or use a blender and mix all ingredients on high speed until smooth. Stop blender, stir and blend again, if
    necessary to combine ingredients.
    2. Pour into two 12-ounce cups.
    Serves 2.
    Quarter Pounder® INGREDIENTS:
    INGREDIENTS:
    1 -Topp's 1/4 lb frozen beef patty
    1 -sesame seed bun
    1 -Tablespoon fresh onion...diced
    mustard, ketchup
    2 -HEINZ hamburger slices (pickles)
    2 -slices real American cheese (optional)
    McDonald's Hamburger Seasoning
    BEEF PATTY ALTERNATIVE: If you can't find Topps™ 1/4 pound patties, use one pound ground chuck, divide into 4 equal pieces, and form the patties about 5" diameter and 1/4"
    thick. Do this on wax paper, and freeze until needed.
    Cooking your Quarter Pounder™
    Pre-heat an electric grill to 400 degrees. (If cooking more than one...also pre-heat an electric grill for toasting the sesame seed buns)Lay the beef frozen patty on the grill, and after about
    20 seconds, "sear" it. Sear a little harder and a little longer than with regular hamburgers.You should apply heavy pressure for 6-8 seconds. Sprinkle liberally with McD's Hamburger
    Seasoning.(see regular burgers to make that) About 2½-3 minutes after searing, turn. Be careful not to tear the sear you just created. Add another dash Seasoning. Lay the crown of the
    bun facedown on an unused, clean portion of the grill. It will toast very quickly, so move it around in a circular motion to prevent burning. After about 30 seconds the bun will be toasted
    enough. Remove to dress, and lay the heel facedown to the same spot on the grill. (If cooking more than one, follow the bun toasting instructions for the regular hamburger.)
    DRESSING THE BUN: Put five "kisses" of mustard around the toasted crown about 1/2 inch from the edge, equally spaced. Then put five squirts of ketchup in the pattern of a five on
    dice and the size of a nickle on the toasted bun. (Make the center one the size of a quarter.) Add about a tablespoon of freshly chopped white onion, and the two pickle slices, evenly
    spaced.
    If you're making a Quarter-Pounder with Cheese™, lay one slice of real American cheese on top of the condiments.Most cheese slices are slightly too big, so cut or tear off about 1/4
    inch, making a slight rectangle.
    By now...your meat should be done. (about 2½-3 more minutes after turning) Smash the beef patty with the spatula to "squeeze" out excess fat, then remove. Smash it again between the
    spatula and your free hand to addtionally drain the fat. Lay it on top of your dressed crown and add the toasted heel. (If you're making a Quarter-Pounder with Cheese™, lay another slice
    of real American cheese on top of the patty before adding the heel. Position the corners off alignment with the other cheese slice)
    Wrap it in a pre-cut 12x12 sheet of waxed paper and either microwave it for 15 seconds, or allow it to be "warmed" in your pre-heated (lowest setting) oven for 8-10 minutes. (or use the
    alternate "Q-ing" method) ENJOY!!!
    McD.L.T.®
    INGREDIENTS:
    1 -TOPPS 1/4 lb frozen beef patty, or alternative*
    1 -sesame seed bun
    1 -slice real American cheese
    1/4 -cup chopped iceberg lettuce
    1 -fresh tomato slice (2 if small)
    1 -tablespoon fresh chopped white onion
    3 -dill pickle slices
    Ketchup, mustard, mayonnaise
    Pre-heat an electric griddle to 400 degrees, and toast both halves of the bun face down on the griddle. It should toast quickly and will have an even light-brown color when done. After
    toasting, set the toasted bun aside. On the same grill surface, cook the beef patty the same way as a Quarter-Pounder® (see cooking instructions for the Quarter Pounder®.)
    DRESS YOUR BUN: On the crown half, apply mustard, ketchup, and onions as described in the Quarter-Pounder™ recipe. Then add 3 pickle slices, the lettuce, followed by 1 tablespoon
    of mayonnaise. Top that with the tomato, then the slice of cheese. (This can be done, and should be done 10-15 minutes before the beef is cooked.) Place in the refrigerator. When the
    beef is done, put it on the heel side of the bun. Then get the dressed crown side out of the fridge, slap the two together, and WACK! A no longer available McD.L.T™!
    McDonald's® McRib™ Sandwich
    Ingredients:
    1 JTM® Brand "Grillin' Ribs" pork patty
    1 6 inch long sandwich bun
    2 Tablespoons McDonald's® Barbecue sauce (see recipe under McNuggets®)
    1 Tablespoon chopped white onion
    3 sour dill pickle slices
    Note** J-T-M™ is the only brand of these pressed and formed pork patties that I've seen. They are shaped like a rack of ribs, just like at McDonald's®. I get
    them at Wal-Mart®. Look for them in the frozen meat section, near the pre-formed hamburger patties.
    Cooking Your McRib®
    1. Preheat your griddle to 400°. Cook the pork patty just like a quarter pound beef patty. (consult the package directions for cooking times and other cooking
    options)
    2. Toast the faces of both halves of the bun, using the bun toasting method described throughout this site.
    3. On the toasted crown (top) half, apply the ready mixed barbecue sauce and follow that with the dill pickle slices, spread out evenly.
    4. Put the cooked "rib" patty on next, then add the onions, followed by the heel. (bottom)
    5. Wrap this masterpiece in a 12x16 sheet of waxed paper, let sit 5 minutes, then microwave on high about 15 seconds, still wrapped.
    6. Enjoy a wonderful McRib® Sandwich!
    Important Notes:
    This is how we did it "back then". However, back then we also just used Bullseye® brand barbecue sauce. (original flavor) You might consider this option.
    Also---this having never been an "official" McDonald's® sandwich, different franchise operators may have prepared it a little differently. Like putting the onions on
    the crown side, or not putting pickles on it. Maybe they put sauce on both sides....etc...etc...Just customize it to the way YOU remember it.
    Arch Deluxe™
    THE SECRET SAUCE:
    1 tablespoon mayonnaise
    1/2 teaspoon Grey Poupon Specialty peppercorn mustard
    Ingredients:
    1 sesame seed hamburger bun (potato roll style with split crown)
    1/4 pound Topps beef patty
    1-2 tomato slices
    1-2 lettuce leaves, chopped
    1 Tablespoon ketchup
    McDonald's hamburger seasoning
    COOKING: 1. In a small bowl, mix together the mayonnaise and the Dijon mustard. Set aside. This is the secret sauce. 2. Toast the face of each of the buns on a griddle as described in all
    other recipes.
    3. Follow Quarter-Pounder cooking instuctions for the beef patty.
    4. Dress your BUN in the following order: On the crown (top bun)
    special sauce
    ketchup
    onions
    lettuce
    tomato
    cheese
    5. Add the cooked beef patty then the toasted heel.
    Makes 1 Arch Deluxe®
    If you want an Arch Deluxe with bacon, pre-cook some thick sliced Hormel® pepper bacon, breaking one slice per burger in half. Lay the halves side by side on top of the cheese before
    adding the meat. (Or just use thick sliced bacon, adding a dash of pepper when cooking.)
    BIG MAC™ Special Sauce
    Ingredients:
    1/4 cup KRAFT Miracle Whip
    1/4 cup mayonnaise
    2 Tablespoons,heaping, WISHBONE deluxe french salad dressing (the orange stuff)
    1/2 Tablespoon HEINZ sweet relish
    2 teaspooons, heaping, VLASIC dill pickle relish (Heinz dill relish also works)
    1 teaspoon sugar
    1 teaspoon dried, minced onion
    1 teaspoon white vinegar
    1 teaspoon ketchup
    1/8 teaspoon salt
    Mix everything very well in a small container. There better be no streaks! Microwave 25 seconds, and stir well again. Cover, and refrigerate at LEAST 1 hour before using.( to allow all of
    the flavors to "meld". ) Makes nearly 1 cup...enough for about 8 Big Macs™.
    Cooking your BIG MAC™
    INGREDIENTS:
    (this is a per sandwich recipe)
    1 -regular sized sesame seed bun
    1 -regular sized plain bun
    2 -previously frozen regular beef patties
    2 -tablespoons Big Mac sauce
    2 -teaspoons reconstituted onions
    2 -hamburger pickle slices
    1/4 Cup -shredded iceberg lettuce
    COOKING:
    Discard the crown half of the regular bun, retaining the heel. The cooking method for the Big Mac™ is basically the same as the regular burgers, only the bun toasting method is slightly
    different. In the Big Mac's case you toast the bottom (heel) first. Do this along with the extra heel. (this will be your middle bun.)
    Cook the two-all-beef-patties just like the regular burgers. After the bun parts are toasted, put 1 tablespoon of "Mac sauce" on each of the heels.(toasted side.) Then add 1/8 cup
    shredded lettuce to each.On the true bottom bun, place one thin slice of American cheese on top of the lettuce. On the extra "heel", the middle bun, place two pickle slices on top of the
    lettuce. Toast the "crown" (top) of the bun also. When the meat patties are done, place them one at a time on both prepared buns. Stack the middle bun on top of the bottom bun, and put
    the crown on top.
    For proper "aging", or "Q-ing", ...wrap the finished Big Mac® in a 12"x18" sheet of waxed paper as follows:
    1...Center the burger, right side up, on the waxed paper. Fold the "long" ends of the paper up over the top. (It will resemble a tube with the burger in the center.)
    2...Fold the two remaining ends underneath. Wrap snug, but don't squish it like the regular burgers.
    3...Let sit 5-8 minutes, allowing the flavors to "meld".
    4...Microwave, still wrapped, 15 seconds on high.
    ....Enjoy an AWESOME Big Mac® Sandwich!
    Big X-Tra®
    INGREDIENTS:
    1 large sesame seed bun (4 3/4-inch diameter)
    1/3 pound ground chuck
    Lawry's® seasoned salt
    1 Tablespoon mayonnaise
    3 HEINZ™ Genuine dill slices
    1/2 cup chopped iceberg lettuce
    1 large tomato slice, or two small ones
    COOKING your BIG X-TRA™:
    1. Form the ground chuck into a large, thin patty on wax paper. Make it approximately 5 1/2 to 6 inches in diameter. Freeze this patty for a couple hours before cooking. (You may consider
    making some in advance, freezing for future use.)
    2. Toast the faces of the hamburger bun as directed in the Quarter Pounder recipe.
    3. Grill the frozen patty on a 400 degree griddle for 2-3 minutes per side. Sprinkle one side with seasoned salt and the other side with McDonald's hamburger seasoning. (recipe is located
    under Regular Hamburgers plus special instructions.)
    4. Dress the crown (top bun) in the following order:
    ketchup
    mayonnaise
    onion
    pickle
    lettuce
    tomato
    *cheese (optional)
    5. Add the cooked patty then the toasted heel (bottom bun)
    6. Wrap the Big X-TRA™ in a 12"x16" sheet of wax paper, let sit 3 minutes, then microwave on high for 10 seconds. Serve.
    Makes 1 Big X-tra®.
    Breakfast Burritos
    4 ounces Jimmy Dean™ breakfast sausage
    1 Tablespoon re-hydrated dried chopped onion ( see regular hamburger recipe for these)
    1 Tablespoon minced mild green chilies (canned)
    1 Tablespoon diced tomatoes (canned, drain liquid)
    4 eggs, beaten to oblivion
    salt, pepper
    4 8-inch flour tortillas
    4 slices REAL American cheese
    On the side: Pace® Picante Sauce
    COOKING your Breakfast Burrito:
    1. Preheat a skillet over medium heat. Crumble the sausage into the pan, then add the onion. Sauté the sausage and onion for 3 to 4 minutes or until the sausage is browned.
    2. Add the mild green chilies and tomatoes. Continue to sauté for 1 minute.
    3. Pour the beaten eggs into the pan and scramble the eggs with the sausage and vegetables. Add a dash of salt and pepper.
    4. Heat up the tortillas by steaming them in the microwave in moist paper towels or a tortilla steamer for 20 to 30 seconds.
    5. Break each slice of cheese in half and position two halves end-to-end in the middle of each tortilla.
    6. To make the burrito, spoon 1/4 of the egg filling onto the cheese in a tortilla. Fold one side of the tortilla over the filling, then fold up about two inches of one end. Fold over the other
    side of the tortilla to complete the burrito (one end should remain open). Serve hot with salsa on the side, if desired. Makes 4 burritos.
    7. Drop on the floor, and serve. (more authentic flavor)
    McDONALD'S® "OLD-SCHOOL" CHEESEBURGER
    Cook the burgers using the regular hamburger recipe and place one THIN slice of american cheese on the crown side before adding meat patty. Don't use Kraft
    singles or Velveeta. (or anything termed as "American processed cheese FOOD) Use only real American cheese. That is KEY! Please Note****Most slices of
    American cheese are too big for McDonald's® cheeseburgers. So take about 1/4" off two edges to make a smaller square.
    McDonald's® Bacon Double-Cheeseburger
    Ingredients:
    2 prepared beef patties
    1 prepared bun
    2 American cheese slices
    1 slice Oscar Mayer® Ready~Made™ bacon
    Prepare the beef patties and buns as directed in the regular hamburger recipe. Dress the bun the same way.
    Microwave the pre-cooked bacon for about 15-20 seconds, tear it in half, and lay the pieces side by side on the dressed crown. Follow that with one slice of
    cheese. Put cooked beef patty #1 on top of the cheese, add another slice of cheese and then beef patty #2. Add the toasted heel and wrap in a 12"x16" sheet of
    waxed paper. (see cooking regular hamburgers for wrapping directions)
    Let sit for 5-7 minutes, then microwave (still wrapped) for 15 seconds until hot.
    Enjoy a classic bacon double cheeseburger!
    McDonald's® Chicken Fajitas
    Special Fajita seasoning:
    1 tablespoon corn starch
    2 teaspoons chili powder
    1 teaspoon salt
    1 teaspoon paprika
    1 teaspoon sugar
    3/4 teaspoon crushed chicken bullion cube
    1/2 teaspoon onion powder
    1/4 teaspoon garlic powder
    1/4 teaspoon cayenne pepper
    1/4 teaspoon cumin
    (or if you're LAZY like me, try using McCormick® fajita seasoning----tastes great and is close enough)
    Ingredients:
    2 large skinless chicken breasts
    1/2 cup chopped green bell pepper
    1/2 cup diced white onion
    2 Tablespoons McDonald's fajita seasoning (see above)
    2 Tablespoons water
    1/2 teaspoon white vinegar
    1/4 teaspoon lime juice, from concentate
    2 slices real American cheese
    4 8" flour tortillas
    cooking oil
    COOKING your FAJITAS:
    1.Cut the chicken into small strips, none longer than two inches, about 1/4 inch thick.
    2. Combine fajita seasoning with water, vinegar, and lime juice in a small bowl.
    3. Marinate chicken in above mixture, covered and refrigerated, for a couple of hours.
    4. Cook marinated chicken strips in a wok over meduim-hight heat until brown. (retain marinade) Use cooking oil to prevent sticking.
    5. Add green pepper and onion, and stir-fry for about 1 minute.
    6. Add remaining marinade, stir-fry until liquid "escapes".
    7. Spoon 1/4 of the mixture into the center of one flour tortilla and add 1/2 slice American cheese. Sprinkle with a dash of your pre-mixed McDonald's fajita
    seasoning. (do this for all four of 'em)
    8. Fold like a burrito with one end open and wrap in a 12x12 sheet of wax paper. Let sit 5-7 minutes.
    9. Microwave, still wrapped, 15 seconds each. (separately)
    10. Drop on the floor for a more authentic taste.
    11. Enjoy with Pace® picante sauce on the side.
    Mods,
    paki delete lang po kung di pwede i-post dito ito. share ko lang sana sa iba, malapit na bumigay hard drive ko baka ma erase, sayang.
    related ka ba sa McDo? saan mo nakuha mga yan? baka kopyahin ng Jollibee :bwahaha: lalo na yung recipe sa french fries!
    Signature
    wow....... thanks!!! i'm a big mcdo fan.. hehehe..
    upload mo rin sa email mo.
    i love mcdo... totoo yun.. fries nila.. ndi tlga magagaya ng jobee.. kahit.. yung new fries ng jobee ndi parin lalamang sa orig mcdo fries... hehe.. i also like twister fries
    pinadala lang po sa email last year, buti nakita ko pa sa harddrive ko. meron pa isa puro fast food recipes 427kb kasama KFC fried chicken & gravy, baileys orig irish cream, chips ahoy, el pollo loco chicken, fig newtons, wendys frosty, etc... kaya lang .exe yon ha. kung gusto nyo send ko sa email nyo.
    thanks glenn, ka u-upload ko lang. buti na lang may gmail na ko.
    pde popa pahingi ng recipes ?
    Nov 2007
    putekk.. nagutom ako bigla
    ako rin pa send dito
    lihimko*hotmail.com
    Apr 2004
    send mo sa akin... paocristobal*yahoo.com
    Apr 2004
    lahat ng fastfood pati mcdo... lalo na yun mga shakes!
    thanks!
    pa send din: boybi*myrealbox.com
    salamat!
    Signature
mac donald recipes...chicken Mcnuggets
