Results 21 to 40 of 54
    Madami pala may home filtration. Mas tipid ba siya in the long run? Kaya lang ako napaisip kasi kung makakatipid ba siya. Wala naman ako problema sa current supplier namin ng tubig. Wala pa naman nangyayari sa amin masama. Hehe
    Mura na rin kasi mga tubig ngayon. 20 per container na lang dito sa amin.
    Quote Originally Posted by flakez View Post
    Depende sa consumption mo. The real benefit is all the hassles of the container are gone. Yun pag de-deliver, buhat, storage, handling, etc. wala na so sa tinging namin mas sulit.
    Sep 2014
    We have our own filtration before but feeling ko kasi di reliable yun nabili namin kaya nagpapadeliver na lang kami. Para kasing masarap yun lasa nun purified samin manamisnamis heeheh
    Oct 2013
    responsibility ng water supplier na panatiliin malinis and potable ang binabayaran ninyo tubig, pwede kayo mag pa test ng water quality kung gusto ninyo...
    dito sa las pinas potable ang tap water c/o maynilad...
    Jul 2013
    I remember when I was living in Japan as a student.
    I get water from the tap because it is okay according to the dorm management.
    Then when the great tohoku earthquake occured and the nuclear radiation contamination risk is perceived high, I bought bottled water by the boxes.
    After a year or so, I decided to go back to drinking from the tap. After a few days, the dorm management sent an email saying the formaldehyde contamination of the river where our water comes from has been addressed. wtf!!! buhay pa naman ako.
    Oct 2013
    Quote Originally Posted by Lew_Alcindor View Post
    a little bit of radiation is good for the body... we get radiation from everywhere... in excess = cancer
    Jan 2003
    We have our own water filtration system same sa mga water refilling station set pero for our own use lang. From the meter meron ng 5 micron filter to begin with which filter mga putik/alikabok such that after every 2 months, puno na yung filter ng parang chocolate. Rinse or replaceable naman yung filter na ito. Tapos it goes to the 2 big filtering tank na iba-iba ang laman each tank and auto cleaning yung mga tanks for long lasting filtration life. Lastly sa drinking faucet in the kitchen meron reverse osmosis with UV filtering while the other faucet has Kanjen water filteration naman.
    The entire set-up cost me 350K more than 5 yrs ago at mahal pa kanjen then. Ngayon mura na lang ang Kanjen filter system.
    Magkano po ba ang ownership cost ng filtration system pang bahay? Can anyone provide ballpark figures?
    Mar 2005
    Gamit namin Unilever Pure It. Laking ginhawa yung hindi ka na oorder ng tubig from Water refilling station.
    Unilever Pureit - Why Pureit is the best water purifier | Pureit Water Philippines
    To be sure pinapa daan ko din sa 2 stage table top fiilter bago ilagay yung water sa Pure It. 1st stage is Ceramic sediment filter at 2nd stage is Activated Carbon filter.
    Mar 2015
    Sir jmpet626 san po nakakabili nito and ano pong model yun ginagamit nyo po? Tia!
    Jan 2013
    nagpapadeliver din kami ng tubig. no choice e,hindi naman pwede inuin yung tap water namin.
    Mar 2005
    Quote Originally Posted by SkyFlakes88 View Post
    Excella model yung sakin. Meron sa True Value at Handyman.
    Quote Originally Posted by jmpet626 View Post
    price range sir? may nakita ako sa Robinson nasa 4k ata?
    Jun 2015
    i use megafresh from ace. easy to find filters
    Aug 2009
    Wag niyo tipirin yan mga sir, mas mahirap pag meron nagkasakit heheh.
    Sa lahat ng may system na sa bahay ask your local health dept and ask cno certified laboratory laspinas and paranaque much union ang credited ask them to test your product if wala bacteria. Dapat monthly yun testing.
    Then sa mga bumibili ng purified dapat TDS level is less than 4microns yan good quality yan more than 10microns it is already mineral. Lagi the lower the better. Ask youre suplier kung ano TDS level
    Aug 2015
    In our house, we use 3 stage filter for drinking water and cooking. Ceramic, Charcoal, Cotton filters connected in our tap water line replacing it every 6 month, roughly 1400 peso yearly.
    Mar 2005
    Current setup ko.
    2 Stage filter connected sa Tap before going sa Pure It Excella. 1st Filter: Granular Activated Carbon 5 micron filtering 2nd filter: Carbon Block 5 micron filtering. Then I pour the filtered water sa Pure It Excella.
    Current setup ko.
    Oct 2013
    Current setup ko.
    Current setup ko.
    overkill naman yan... yong savings mo sa pureit napupunta dun sa filter cost mo sa unit before pureit...
    ang maganda sa pureit may users manual siya, anything printed wrong dun eh pwede mo i file ng law suit against them if it fails...
    Oct 2013
    dito sa amin sa muntinlupa, pwede na ang activated carbon ng tupuro kasi chlorinated naman siya ng maynilad... basta mataas ang pressure ng tubig ok para tulak palabas ang dumi sa under ground pipe at makita agad nasaan ang leak...
    ang problema kase dati, low water presure sa maynila, kaya pag may pump ka sipsip mo lahat ng dumi sa broken underground pipe, plus di mo makita nasaan ang leak...
Drinking water - purified at home or water refilling station
