Originally Posted by
rsnald
madali lang mag-adjust ng valve clearance, you just need the proper tools (17mm, 14mm, 12mm, and 10mm wrenches, 0.40mm spacer gauge, philips screwdriver) at lakas ng loob hehehe. other things to check:
1. Fan belts
2. alternator belt
3. tire thread depth (kung pudpod na gulong mo)
4. better din kung magpa alignment ka na. servitek ok na sila. wag rapide.
5. check your battery condition na din, tutal lampas na warranty ng battery, tanggalin mo yung sticker covering the battery, unscrew mo yung individual cap ng battery compartment and check/refill with distilled water.
6. brake pads, palinis lang siguro. me, I changed my front brake pads after more than 90,000km.
7. repack front wheel bearing - sa servitek din.
yan lang naiisip ko as of now... fill-in na lang ni master xwind kung ano kulang.
