Hi guys. I'm a newbie with cars and this site has greatly helped me since i joined. Last week, i availed of the Honda Homecoming promo where you can bring your 2nd Honda and have it thoroughly checked. I brought my 2nd hand 1997 Honda Civic VTI A/T to Honda, Pasig. After the free 112 points check-up, they gave a list of spare parts that need to be replaced right away. However, if I am going to have it fixed in the casa, I could not afford the quotation. So I decided to just buy the spare parts outside and have it replaced also outside. I would just like to ask Honda owners if you know of reliable shops and auto supply stores where i can buy replacement parts? I listed the needed parts below. Feel free also to post here if you are aware of the price for the sake also of other tsikoteers. Thanks a lot.
For immediate replacement:
Oil Pan Gasket
Front crankshaft oil seal
camshaft oil seal
rear crankshaft oil seal
oil pump o-ring
manual valve oil seal
torque converter o-ring
distributor oil seal
valve cover gasket
lock up sound valve o-ring
P/S belt
Front L/R Shock unit
thanks dude. will text you when i decide to purchase na. are there other pick up areas aside from makati? from angono, rizal kasi ako. how about megamall?
i'm with mr speedyfix on this one. original honda dapat jan. the shocks you can buy outside, but those gaskets etc etc... bilhin mo sa loob ng casa. honda quezon avenue reputedly sells cheaper than most honda casas.
yung oil pan gasket is particularly tricky. there is a method sa paghigpit nyan, else, sisingaw ulit and your engine will weep oil from the underside.
your car is quite old... gastusan mo na lang sa casa yan dude, best not to take chances. kung underchassis suspension yan, a/c, oil changes and tune ups pwede kahit saan, pero yung mga critical components... well, casa talaga.
thank you for the replies. I will try to inquire from Honda Quezon Ave.
* Sir speedyfix, I sent an inquiry thru your website pero wala pang reply. How much if I will have this fixed in your shop? I used to go to your shop when you were still in San Juan, across ConceptOne. You may PM me for the quotation. Thanks.
