Results 1 to 8 of 8
    Nov 2007
    Where can you find the air intake adjust valve of a Honda Civic '04?
    Vti M/T
    1.6 VTEC3 engine
    eto kasi
    everytime i kick the throttle and suddenly release it, the RPM dives to about 300rpm or lower for less than two seconds then goes back to the normal 750-800. Sometimes, the engine completely stalls. The bad part is that it usually happens when moving, so when shifting, at high speeds, the engine stalls sometimes and i have to restart.
    It happens while moving most of the time. But when parked, it happens but most of the time it's normal (drop to about 1000rpm and down to 800rpm). Only when moving or "gliding" lang talaga.
    Wala naman problem ang engine itself, malakas ang hatak and can rev to redline without bad signs.
    Our trusted mechanic said its most likely because of the air intake, but he couldnt find the adjusting valve. Does anyone know where it's located? Near what? any pics? thanks!
    Nov 2003
    you can't adjust the idle air. have the throttle body cleaned pati the sensors. normally that solves the problem.
    May 2007
    Quote Originally Posted by speedyfix View Post
    This is true, idle air are factory sealed. If you touch that bye bye to your waranty. Also 1000 RPM on idling are way off, Normal RPM idling on your honda is 700. If your RPM flactuated check for a vacuum leak like vacuum hose leaking , clog oropice or there is a leaked in the intake manifold.
    Apr 2004
    sounds like your valve tappets need adjustment. maybe even a good throttle body clean.
    Nov 2007
    okay thanks for the suggestions. ill have it checked.
    what i meant by 1000rpm is that when moving at a high speed then ilagay sa neutral, bababa ang rpm sa 1000, then once bumagal na ang car, bababa sa idling speed na 750.
    thanks for the replies
    Nov 2003
    dropping to 1000 before 700 is fine. it's dropping to 300 that you have to fix.
where can you find the air intake adjust valve of a Honda Civic '04?
