Page 1 of 2 12 LastLast
Results 1 to 10 of 11
    Apr 2004
    Guys, nalilito na ako. Pag sinabi bang tune up, ibig sabihin ay oil change, oil filter change at spark plug change?
    Or all of the above, plus valve adjstment, timing adjustment, carb re-jetting, ecu reset?
    Di ko na kce ma differentiate kung ang ibig sabihin nila sa tune-up ay regular maintenance or something beyond that na kakalikutin sa makina para mag-iba/ma-fine tune ang andar ng kotse mo... tnx in advance.
    Dec 2003
    As far as I know, change oil, & spark plugs lang, tapos clean air filter.
    signs your car needs a tune-up:
    has this happened to you? your car stalls in traffic when the air conditioner is turned on? or di kaya it keeps running after the ignition is turned off? these are classic signs your engine is overdo for attention.
    Minor tune-up:
    - clean/replace Spark Plugs
    - clean/replace Air Filter
    - replace fuel filter
    - battery and charging system analysis
    - adjust idle speed and timing where applicable
    - adjust/replace fan belts
    - inspect tires and adjust tire pressure
    Major tune-up:
    - replace spark plugs
    - replace air filter
    - replace fan belts
    - inspect tires, tire rotation and adjust tire pressure
    - inspect brake pads
    - inspect/replenish car's fluids (motor oil, transmission oil, brake fluid, power steering fluid & coolant)
    - valve adjustments (tappeting yata tawag nila dun?)
    Apr 2004
    so basically a tune up is just the regular maitenance routine for your vehicle?
    Nov 2003
    yep!
    valve adjustments (tappets) is usually a major job na which will take longer than the usual hour for the normal tune-up
    Apr 2004
    Guys,
    yung isang Car namin naka 6A12 DOHC engine or galant...
    Inaadjust din ba ang timing nito at tappets? Sabi kasi ng mechanic SELF-ADJUSTING daw.
    Is this true?
    Apr 2004
    m not sure... basically when i was still driving a diesel pickup, kasali sa "tune-up" yung pag adjust ng tappets, rocker arms at kung ano ano pa na nasa likod ng valve cover. anyway, napansin ko lang yung nag-sedan na ako (DOHC 16valve), na puro oil, oil filter and sparks nalang ang pinakikialaman during maintenace. siguro since our pickup doesnt have over - head cams that's why kailangan i-adjust yung mga items mentioned, whereas sedans nowadays have over head cams, so wala na silang mga rocker arms and stuff... m not sure though.
    Jan 2004
    yes, wannabe, your gallant's engine is equipped with hydraulic valve-lifters so there is no need to adjust it.
    Nov 2003
    there are different types of valvetrain components. some require manual adjustments (honda) while others cannot be adjusted without replacing parts (i.e. newer model corona's, etc)
    pina-tappets ko yung galant ko nung recent tune-up pero 4g63 SOHC yung akin. sarap ng hatak!
what's a tune up?
