Page 2 of 2 FirstFirst 12
Results 21 to 27 of 27
    #21
    Quite a old thread pero very interesting ang topic,
    Mixing Gasoline and Diesel, "NEVER"....di pwede paghaluin ang dalawa, dahil mas lower flash-point ang gasoline at mas higher flashpoint ang Diesel....
    Quote Originally Posted by SiRbossR View Post
    Okay lang kerosene. Diesel engines can run on kerosene if needed but it is not recommended. And yes you can mix kerosene and diesel.
    Posted via Tsikot Mobile App
    Sir SirbossR..
    Agree for that Sir!, possibly pwede po talaga paghaluin ang diesel at kerosene.. (lubricating properties, content and temp. po ang difference) mas mataas lang po ang diesel sa lubrication properties rather sa kerosene. Recommended lang po talaga kung extreme cold weather, (correct me sir kung mali po ako), pero dito sa pinas ay tropical area, kaya hindi po talaga advisable.
    Same din sa gasoline, (pwede paghaluin ang blaze at avgas)...
    May 2010
    #22
    ^actually pwede. At the right ratio, it is fine.
    May 2010
    #23
    OT: Avgas requires specific engine oil. Di pwede regular motor oil dapat the likes of aeroshell. Cause if you do use avgas as substitute to gasoline mauubos engine oil mo.
    #24
    Sir SiRbossR,
    Hehe As long as po na pasok dun sa SAE viscosity, proper fuel type used + the "supplementary type certificate", (reciprocating)no problem po...
    pero sa land vehicles, same concept, yung lang po, hindi ganoon katibay during ops, lalo sa temp. not unless kung may mga certain mods...applicable pa rin....(di allowed dahil sa world politics)...hehehe
    May 2010
    #25
    Quote Originally Posted by playplugg View Post
    Sir SiRbossR,
    Try it sir, you'll see what I'm all about
    Dec 2012
    #26
    Kailangan talaga magresearch. Mixing diesel and kerosene has been a long practice. Palagay ko yung ranger owner was advised of using kerosene for cleaning effect. Pero dahil hindi magkatabi ang pump ng diesel at kerosene, baka naisip nya gasoline na lang tutal magpinsan naman ang kerose-ne at gasoli-ne.
    Jun 2011
    #27
    Baka nga hindi gasolina inihalo, baka kerosene.
    Sana walang rubber hose sa fuel line baka matunaw.
What's the reason for adding gasoline when refueling with diesel?
