Originally Posted by
zeus_em
Hi po,
I think we have the same issue, I have poor fuel consumption as well. I'm driving a civic vti. Together with that issue, I'm having an idle problem too. When ever I turn on A/C idle drops almost to 2000 rpm. Anyway I have a question po. What do you mean by 10-12 tune up adjustment and where do you have your car tuned up. TIA po. Btw newbie po ako.
Thanks in advance uli.
Sir you probably mean 200 RPM? The RPM drop is mostly caused by a bad or failing IACV. a.k.a Servo motor.
Good day people.
I have this honda civic lxi model. And this is the scenario. At first the car have this overheat problems during long trips w/c leaves no water at the radiator. We removed the thermostat and have engine tuned up and no leaks were found in the radiator however we observed that when the car revs high,
the water in the radiator pumps its water out to the reservoir little by little. After a week, the
car would no longer start. It was found out that the valves were worn out so we change the valves and so the car finally went ok. Tune up was done and change oil too. Only to find out that it was already consuming too much fuel. From 12-13 km/liter, now 7-8 km/liter.. The car feels great naman. Tune up adjustment is 10-12 kasi noong 9-11 sya na mejo tumataas engine temp. Anong normal setting pala para makatipid?
My inquiry po:
What must have cause the poor fuel consumption?
Sir it's possible that your valve clearances are not properly adjusted. Or timing might be a bit off. Those are the things you should check and your FC should improve.
