Results 1 to 11 of 11
    hey tsikoteers,
    just wanna get your tips on what and how to check/lookout for in the engine when buying a 2nd hand diesel-engined vehicle.
    i would be getting one soon and unfortunately i may not have a mechanic with me all the time when i check my options. so far i do have a bit of knowledge on gas engines. hope you could help! thanks in advnace!
    Talk to the head mechanic of the surplus shop, sabihin mo "bigyan mo ako ng sariwa ako na bahala sa iyo."
    Or if you are permited or masimplihan mo remove glow plug ng cylinder #4. Then biglang kabitan mo ng compression tester. Sabay start mo na. Never start before mo makabit ang gauge.
    almost the same naman ang pag check sa diesel and gas engine. it should start easily (one click) after the heater lamp goes out. warm up the engine. wait until it reaches operating temp. maki pag kuwentuhan ka muna sa seller or inspect mo other part/interior ng vehicle wait waiting. open oil filler cap and or pull out dip stick. see if any puffs of smoke comes out from it. kung kaunti lang puede pa yan. worse pag oil na lumalabas sa dipstick or sa filler cap blowby na yun. pero minsan talansik lang yun from the tappets. check for oil leaks. normally pag sa harap mga seals ng pulley yun. if pawis lang ok pa yun. check mo hose going to the alternator .
    4JGtootsie,
    hmmm parang mahirap yung compression test a and wala akong gamit.
    afrasay,
    actually yun ang fear ko e. yung may lamat yung internals. pero similar din nga sa gas pala ang pagtest sa pagbuga ng oil.
    may nagsabi din sa akin na yung smoke sa tambucho normal lang especially kung malamig pa makina. pero kung white smoke, masama daw. kung black, ok lang. at kung bumuga yung radiator, may tama na rin ang block. tama ba? and how would you know kung may history ng overheat?
    sensya na po sa dami ng tanong ha. 1st time ko kasi. hehehe thanks sa replies at hope more to come!
    usually pag maganda pa makina may spots of water na lalabas sa muffler pag bagong andar. tama ka, yun radiator check mo rin. water should be just flowing and not producing bubbles. take it for a spin. tignan mo yun hatak ng engine. then when you park it open mo yun hood and check inside the bay.
    Sorry, i thought engine lang and bibilhin mo.
    Quote Originally Posted by coiter View Post
    hey tsikoteers,
    What Car ba?
    Mas maganda kung medyo upgrade mo na makina... or d same padin bibilin mo?
    May kilala ako sa Banaue, pero mas mura sa Blumentritt kumpleto
What and how to check/lookout for in a diesel engine
