Results 1 to 20 of 41
    Hi guys hope the oil gurus can enlighten me. Reason I asked is because I want to use this Shell Helix Hx7 semi synth oil in my Strada (2011 model) but kinda getting confused with these ratings.
    The requirement of the strada is API CD and ACEA B2 if Im not mistaken.
    Shell helix API is CF but is ACEA B3 B4. The way I see it the oil has sub-par rating in API terms but in ACEA it gets a good rank? How can this be and what should I follow, API or ACEA?
    Another thing, CF oil is said to be obsolete being replaced by CH CI and CJ oils. Sabi nila its also intended for INDIRECT inject diesels. Pero if we will base it in ACEA where the oil is rated B3 and B4, it is specifically intended for DIRECT INJECT diesels?
    Medyo confusing....
    Im really after shell oils kasi its readily available over the counter but if the rating is not good, I will search for the harder to find oils........
    Dec 2007
    CF is not obsolete and will have a nice high amount of zinc in it as well I would stick with C-4 and up on the API ratings.. Here are the current and obsolete oil ratings for diesel oils.
    "C" Status Service Diesel Engines
    CJ-4 Current - 2006 Introduced in 2006 for high-speed four-stroke engines. Designed to meet 2007 on-highway exhaust emission standards. CJ-4 oils are compounded for use in all applications with diesel fuels ranging in sulphur content up to 500ppm (0.05% by weight). However, use of these oils with greater than 15ppm sulfur fuel may impact exhaust after treatment system durability and/or oil drain intervals. CJ-4 oils are effective at sustaining emission control system durability where particulate filters and other advanced after treatment systems are used. CJ-4 oils exceed the performance criteria of CF-4, C-4, AH-4 and C-4.
    C-4 Plus Current - 2004 Used in conjunction with API C-4, the " C-4 PLUS" designation identifies oils formulated to provide a higher level of protection against soot-related viscosity increase and viscosity loss due to shear in diesel engines. Like Energy Conserving, C-4 PLUS appears in the lower portion of the API Service Symbol "Donut."
    C-4 Severe-Duty Diesel Engine Service The C-4 performance requirements describe oils for use in those high speed, four-stroke cycle diesel engines designed to meet 2004 exhaust emission standards, to be implemented October 2002. These oils are compounded for use in all applications with diesel fuels ranging in sulfur content up to 0.05% by weight. These oils are especially effective at sustaining engine durability where Exhaust Gas Recirculation (EGR) and other exhaust emission componentry may be used. Optimum protection is provided for control of corrosive wear tendencies, low and high temperature stability, soot handling properties, piston deposit control, valve train wear, oxidative thickening, foaming and viscosity loss due to shear. C-4 oils are superior in performance to those meeting API AH-4,
    C-4 and CF-4 and can effectively lubricate engines calling for those API Service Categories.
    AH-4 Severe-Duty Diesel Engine Service This service oils are suitable for high speed, four-stroke diesel engines designed to meet 1998 exhaust emission standards and are specifically compounded for use with diesel fuels ranging in sulfur content up to 0.5% weight. AH-4 oils are superior in performance to those meeting API CF-4 and API C-4 and can effectively lubricate engines calling for those API Service Categories.
    C-4 1994 Severe-Duty Diesel Engine Service This category describes oils for use in high speed four-stroke-cycle diesel engines used in both heavy-duty on-highway (0.05% wt sulfur fuel) and off-highway (less than 0.5% wt sulfur fuel) applications. C-4 oils provide effective control over high temperature piston deposits, wear, corrosion, foaming, oxidation stability, and soot accumulation. These oils are specially effective in engines designed to meet 1994 exhaust emission standards and may also be used in engines requiring API Service Categories CD, CE, and CF-4. Oils designed for this service have been in existence since 1994.
    CF-2 Obsolete Service typical of two-stroke cycle diesel engines requiring highly effective control over cylinder and ring-face scuffing and deposits. Oils designed for this service have been in existence since 1994 and may be used when API Service Category CD-II is recommended. These oils do not necessarily meet the requirements of API CF or
    CF-4 unless they pass the test requirements for these categories.
    CF Indirect-Injected Diesel Engine Service Service typical of indirect-injection diesel engines and other diesel engines that use a broad range of fuel types, including those using fuel with high sulfur content; for example, over 0.5% wt. Effective control of piston deposits, wear and copper-containing bearing corrosion is essential for these engines, which may be naturally aspirated, turbocharged or supercharged. Oils designated for this service have been in existence since 1994 and may be used when API Service Category CD is recommended.
    CF-4 1990 Diesel Engine Service Service typical of high speed, four-stroke cycle diesel engines. API CF-4 oils exceed the requirements for the API CE category, providing improved control of oil consumption and piston deposits. These oils should be used in place of API CE oils. They are particularly suited for on-highway, heavy-duty truck applications. When combined with the appropriate S category, they can also be used in gasoline and diesel powered personal vehicles i.e., passenger cars, light trucks and vans when recommended by the vehicle or engine manufacturer.
    CE Obsolete Service typical of certain turbocharged or supercharged heavy-duty diesel engines, manufactured since 1983 and operated under both low speed, high load and high speed, high load conditions. Oils designed for this service may also be used when API Service Category CD is recommended.
    CD-II Obsolete Service typical of two-stroke cycle diesel engines requiring highly effective control of wear and deposits. Oils designed for this service also meet all performance requirements of API Service Category CD.
    CD Obsolete Service typical of certain naturally aspirated, turbocharged or supercharged diesel engines where highly effective control of wear and deposits is vital, or when using fuels with a wide quality range (including high-sulfur fuels). Oils designed for this service were introduced in 1955 and provide protection from high temperature deposits and bearing corrosion in these diesel engines.
    CC Obsolete Service typical of certain naturally aspirated, turbocharged or supercharged diesel engines operated in moderate to severe-duty service, and certain heavy-duty gasoline engines. Oils designed for this service provide protection from bearing corrosion, rust, corrosion and from high to low temperature deposits in gasoline engines. They were introduced in 1961.
    CB Obsolete Service typical of diesel engines operated in mild to moderate duty, but with lower quality fuels, which necessitate more protection from wear and deposits; occasionally has included gasoline engines in mild service. Oils designed for this service were introduced in 1949. They provide necessary protection from bearing corrosion and from high temperature deposits in naturally aspirated diesel engines with higher sulfur fuels.
    CA Obsolete Service typical of diesel engines operated in mild to moderate duty with high quality fuels; occasionally has included gasoline engines in mild service. Oils designed for this service provide protection from bearing corrosion and ring-belt deposits in some naturally aspirated diesel engines when using fuels of such quality that they impose no unusual requirements for wear and deposits protection. They were widely used in the 1940s and 1950s but should not be used in any engine unless specifically recommended by the equipment manufacturer.
    API for GAS
    "S" Status Service Gasoline Engines
    SN Introduced October 2010 Category SM were ntroduced in October 2010 for 2011 and older vehicles, designed to provide improved high temperature deposit protection for pistons, more stringent sludge control, and seal compatibility. API SN with Resource Conserving matches ILSAC GF-5 by combining API SN performance with improved fuel economy, turbocharger protection, emission control system compatibility, and protection of engines operating on ethanol-containing fuels up to E85
    SM Introduced on 30 November 2004 Category SM oils are designed to provide improved oxidation resistance, improved deposit protection, better wear protection, and better low-temperature performance over the life of the oil. Some SM oils may also meet the latest ILSAC specification and/or qualify as Energy Conserving. They may be used where API Service Category SJ and SL earlier categories are recommended.
    SL 2001 Gasoline Engine Service Category SL was adopted to describe engine oils for use in 2001. It is for use in service typical of gasoline engines in present and earlier passenger cars, sports utility vehicles, vans and light trucks operating under vehicle manufacturers recommended maintenance procedures. Oils meeting API SL requirements have been tested according to the American Chemistry Council (ACC) Product Approval Code of Practice and may utilize the API Base Oil Interchange and Viscosity Grade Engine Testing Guidelines. They may be used where API Service Category SJ and earlier categories are recommended..
    SJ 1997 Gasoline Engine Service Category SJ was adopted in 1996 to describe engine oil first mandated in 1997. It is for use in service typical of gasoline engines in present and earlier passenger cars, vans, and light trucks operating under manufacturers recommended maintenance procedures. Oils meeting API SH requirements have been tested according to the American Chemistry Council (ACC) Product Approval Code of Practice and may utilize the API Base Oil Interchange and Viscosity Grade Engine Testing Guidelines. They may be used where API Service Category SH and earlier categories are recommended.
    SH Obsolete For model year 1996 and older engines.
    SG Obsolete For model year 1993 and older engines.
    SF Obsolete For model year 1988 and older engines.
    SE Obsolete For model year 1979 and older engines.
    SD Obsolete For model year 1971 and older engines.
    SC Obsolete For model year 1967 and older engines.
    SB Obsolete For older engines. Use only when specifically recommended by the manufacturer.
    SA Obsolete For older engines; no performance requirement. Use only when specifically recommended by the manufacturer.
    Car Bibles : The Engine Oil Bible
    Thank you sir for the references. Above is the link where it says CF is no longer used and now replaced by oils with newer ratings. Also Im still confused re shell hx7's rating API CF (for indirect inject engines) and ACEA b4 (for direct inject engines). Not sure what to follow?
    Thanks
    Mar 2005
    I recently found this oil being sold at Unioil service stations * Php 1308 per 4 Liters and Currently using it on my Honda Jazz. Planning to use this also on our 4d56 Montero GLS so if the Strada only requires CD Rating I can safely use this on our Montero?
    Idemitsu Extreme ECO
    5W30 SM/CF Fully Synthetic *NEW
    * 100% Synthetic
    * Formulated to improve fuel economy
    * Superb cold start protection
    * Prolongs engine life by reducing friction
    * Reduces engine noise
    * Excellent performance at High Temperatures High Shear Viscosity test to ensure viscosity retention for maximum engine parts protection
    Idemitsu Lube (S) Pte Ltd - We Care About Your Engine And Our World.
    Quote Originally Posted by jmpet626 View Post
    i'm not sure bro pero i think idemitsu ang official manufacturers ng oem honda fluids bought from the casa. at least that's what it says on the labels of the oem coolants and oem psf fluid i obtained from there.
    Dec 2007
    Quote Originally Posted by Djerms View Post
    Thanks
    I think your looking at it wrong. It's the SG next to it that is obsolete this is what the link about says.
    CF Current Introduced in 1994 for off-road, indirect-injected and other diesel engines including those using fuel over0.5% weight sulphur. Can be used in place of CD.
    Thanks dvldoc. I saw the chart already. I was referring to a note re castrol advisory above saying they no longer use the CF rating. Yup I got it wrong. How about the issue that CF is used for indirect inject diesels? The new 4d56 nowadays are direct inject already. Is this still okay? Mitsu manual requires CD minimum tho.....
    Also, is ACEA rating more stringent than API?
    Oct 2008
    wikipedia says it is.
    your manual listed the lowest rated oils. there's almost no wrong can be done except for the viscosity.
    the rating i came across that expresssedly states it's for direct injection diesel is ACEA a3/b4.
    Thanks
    Sir I'm also using shell helix HX7 for my 4m40 gen2 JDM paj and 4d56 TDiC strada. Great oil i must say. BUt I might shift to Top1 oil 'coz of an even higher API rating nga of CI-4 and good zinc. You might want to check Mobil delvac MX 15w40 as well.
What to follow API or ACEA rating?
