Results 1 to 6 of 6
June 25th, 2004 02:52 PM #1
nissan / b12 / carb type.
Idling drops from 700rpm to 300rpm which nearly turns the engine off. It vibrates as if somebody is yacking on the car.
any help?
- Mar 2004
- 434
June 25th, 2004 06:02 PM #2i had the same problem with our old car. the problem was the fuel filter. it was clogged. and water on the tank.
but in my civic vti before it was a different problem. it was the aircon compressor acting up. may parang clutch dun na nagloloko kaya bumbagasak yung idle.
June 27th, 2004 11:51 AM #3
same experience a couple of days ago.
i haven't check it thoroughly but its gone now.
yup, my suspect is also dirty filter, but i believe the possible culprit is water on the tank.
badtwip.
pag malapit na sa empty tank ko, palinis ko sa gas station.
- Jul 2004
- 1
July 18th, 2004 09:37 AM #4yeah same here.. pero pg nag aircon ako, ang taas nman ng idle. mga guru's help nmn jan....
August 3rd, 2004 05:33 PM #6
i just put those penzoil(<-spelling)2 in 1 octain booster and fuel cleaner w/ a full tank of gas. . . . whalah, wala na problem.:D
