Page 1 of 3 123 LastLast
Results 1 to 20 of 43
    Sep 2016
    Ano po kaya reason bakit nag jejerk yung vios namin when accelerating.
    year? ignition coil probably... clean the throttle body?
    Sep 2016
    2010 1.3J Model po sir.
    Sep 2006
    Spark plugs?
    Spark plugs?
    pwede rin pala.. copper lng ata nilalagay nila sa factory. 5years nadin..
    Sep 2016
    Salamat sa mga inputs sir, pa tingin ko na lang sa mechanic kasi kanina ko lang na experience yung pag jerk eh pati sa pagtimpla ng clutch lakas ng jerk eh para tuloy akong bago sa pag drdrive ng manual hahahaha
    Sep 2016
    posible lahat ng sinabi nila. spark plugs, ignition coil, air filter o fuel filter, marumi throttle body at isa pa palinis na din ng MAF sensor :-)
    Mar 2004
    Most likely clogged fuel filter ...
    Jan 2003
    What fuel arr you using para pinakabasic muna.
    Quote Originally Posted by ReggieMar View Post
    is this a new development, or has this been with the car since new?
    Sep 2016
    Sir new development palang po. kakapa change oil, change filter ko pa nga lang sa petron I think 700km palang natatakbo after the procedure ng vios sa petron.
    Sep 2016
    Quote Originally Posted by A121 View Post
    Hi Sir, I'm using Petron Extra and Caltex Silver
    Apr 2014
    Anong oil thickness ang ginamit? At ilang liters ang nilagay? Lagpas ba sa full sa dipstick?
    Sep 2016
    Quote Originally Posted by chronicle View Post
    Sir gamit ko po Petron Ultron Gasoline Engine Oil Touring Premium Multi-Grade API SL/CF SAE 20W-50, and yes lagpas po sa full dispstick.
    thank you sir
    my wild guess would be, your engine is pre-igniting. check ignition timing, po, and adjust if needed.
    my other thought is, you need higher octane fuel, or better fuel quality.
    btw, how's your fuel filter?
    thank you sir
    20w50? ouch....
    who recommended this?
    Sep 2016
    20w50? ouch....
    The petron guy sir 🙁
    nawawala jerking after driving over 1hr? or only when you leave the house?
    Sep 2016
    Sir at certain speed po minsan at 70-80kph nag jejerk sya eh medyo ramdam tlga eh kasi napaka unusual
    oil viscosity is out of the question.. at that speed the oil is already at operating temp even though its thick...
    meron ba check engine light?
Vios jerking when accelerating
