Results 1 to 5 of 5
- Nov 2004
- 45
June 28th, 2010 09:55 AM #1Guys good day!
I would like to ask some help regarding my ride [ Altis automatic 2003 ]
Whenever I would start to gas up parang may nag vi vibrate na sound . This happens i think at low rpms or the vehicle is at first gear.
The vibrating sound is not so loud. It kinda goes on and off. After the vehicle goes to greater than 60 kpm the vibrating sound stops.
Nga pala when I am in drive mode and stepping the brake. The vibrating sound happens again.
Any opinions
Thanks in advance
- Apr 2010
- 38
June 29th, 2010 09:55 AM #2hindi ko alam kung same yung problem natin.., I'm drivin Vios 1.3J 2004 model.., from full stop upon stepping the gas with the first and while I release the cluth nagvi-vibrate sya na parang mamatay yung makina.., pero pag diniinan mo yung gas para tumaas yung rpm nawawala naman.., sabi sakin nang friend ko.., it has something to do with my clutch lining.., pero hindi ko pa napapalitan yung sakin..,
- Apr 2010
- 38
June 29th, 2010 10:51 AM #3at saka may nagvivibrate pala under the hood at sometimes even at idle.., parang yung intake yung nagvivibrate.., I've already adjusted the clutch pero ganun pa din..,
June 29th, 2010 11:28 AM #4
Baka manipis na clutch lining mo at check mo rin iyong engine support mo baka worn out na.
June 29th, 2010 01:06 PM #5
if it sounds like tin cans jingling, check your exhaust heat shields. some cars now have a wire mesh with the washer that they use to mount the shield to the exhaust manifold. the heatshield itself sometimes develops cracks from the heating/cooling cycle accelerated by theengine vibration
Thread was made nung 2018 pa po sir.
