Results 11 to 16 of 16
Tsikot Member Rank 5
- Nov 2003
- 3,848
April 5th, 2007 09:47 PM #11magastos talaga ang kotse... cheaper in the long run if you spend on it from the start
April 11th, 2007 09:44 AM #12
Para sa akin hindi na kailangan ang engine flush kung regularly naman ang change oil. Usually ginagamit lang to sa mga repairs na makapal na yung sludge at mahina na ung oil pressure due to restricted oil pump pick-up pipe. Another simple thing is the stuck open thermostat, it can cause the engine not to reach operating temperature promoting oil sludging. Regularly maintain also PCV system and engine breather.
- Feb 2007
- 11
April 21st, 2007 09:14 PM #13Using 2 cans of engine flush? siguro kapatid sya ni asiong aksaya he he pwede ngang di na gamit ng flush basta regular ang change oil mo
April 21st, 2007 10:31 PM #15
Ako pag sa casa, i request them NOT to use engine flush. We just wait it out. Di naman ako nagmamadali e. hehe.
April 22nd, 2007 08:00 AM #16
I was convinced that engine flush is not necessary, so I stopped using it. It's just a waste of money.
Yes, because 100 degree boiling point is measured at sea level. What's interesting also is that...
