Results 1 to 10 of 12
- Nov 2012
- 17
December 6th, 2012 07:18 PM #1Hi sirs,
Naglilight-up po yung check engine ng kotse ko. I first noticed this, four months ago, after I had an engine wash. I've made a research and I read na it happens pag daw may nabasang wiring or something. Solution was to remove the battery then ikabit ulit. It worked! Ngayon, naglilight-up na naman sya. I wonder if may alam po kayong pwede kong pagpatingnan? Somewhere in Makati, Bicutan, or nearby areas po sana...
TIA
December 6th, 2012 09:06 PM #2
Why don't you just do the same thing as last time. Over time moisture may dry up.
December 8th, 2012 10:41 AM #4
if it worked before, it will work again unless something is wrong. maybe an OBD scan will pinpoint the problem..
December 8th, 2012 10:57 AM #5
- Oct 2009
- 2,271
December 8th, 2012 05:11 PM #6ok lang magpa engine wash...basta tanggalin ang battery- negative saka pa spray ng hangin gamit ng compresor para siguradong tuyong tuyo ang mga wiring..
saka ikabit ang battery
- Nov 2012
- 17
December 10th, 2012 03:36 PM #7hindi nga po natanggal ang battery-negative. parang binalutan lang n plastic engine detail nlng next time hehe.
anyway, saan po kaya pwede magpa-OBD Scan? somewhere near paranaque or makati sana...
TIA
December 10th, 2012 03:49 PM #8
- Dec 2003
- 51
- Feb 2012
- 40
January 9th, 2013 07:23 PM #10Bumili ka nalang ng OBD scanner. P3k lang wifi version na. Tapos puede mo pa view sa iPhone yung engine performance and all sort of other stuff.
Suzuki JIMNY [merged threads]
