Page 1 of 2 12 LastLast
Results 1 to 20 of 23
    Toyota 2C Normally Aspirated Engine:
    Mga Sir,
    Pinalitan ng mechaniko ung water pump pero kailangan tanggalin ang timing belt.
    Pag kabit nag hard starting tapos maingay di ko alam kung fuel o mechanical knock eh.
    Pero di naman ginalaw ung posisyon ng crank and camshaft eh.
    Ano kaya magadang gawin? Nasira kaya ang camshaft or valves ko?
    Thanks in advance.
    Aug 2004
    Better to have it double-checked to be sure. Even if you don't think you moved anything, you're not sure unless you've checked the alignment of the timing marks.
    the timing is off
    Thansks. Is it the injection timing?
    crankshaft to camshaft index
    Aug 2004
    Quote Originally Posted by t2erns View Post
    Yup. Yun nga yun.
    Thanks sa inyo. Wala ba kayo kiala mekaniko (makinista) laspinas area?
    Update : Binalikan mekaniko, di na sya hard starting medjo nausok lang ang problema maingay ano kaya problem ngayon?
    ano ang suspetsa ng mechanic mo sir? para magkaroon tayo ng idea
    I just fired him.
    Sabi nya injector daw. Ung tunog kasi parang pina amoy mo un diesel ng lighter fluid nag aaccellerate ung tunog na parang sasabog ung makina. Chinek ng kapatid ko ung timing may konting off siguro 1 teeth ng belt tapos ung injection pump imbis nasa uno ung pointer nasa kabilang dulo. Ang pinagtataka ko bakit wala sya gaano usok at tumatakon naman. Di ko pa alam kung ano nagnyari kasi iniwan ko kapatid kong engineer na gumagawa baka bukas may update na.
    Halos ganito ung tunog pero walang ganyang tunog dati. YouTube - ‪6.2 diesel injector knock‬‏.
    Parang ganto rin ung tunog minus the smoke tapos from cold start heater ko sya 10 secs. tapos starter for 3 secs mga 2 to 3 tries mag start sya [ame=http://www.youtube.com/watch?v=orbbourGCOQ&feature=related]YouTube - ‪6.5 diesel injector knock 1‬‏[/ame]
    May 2009
    Thanks sir Miked.
    I pasted the link http://www.car-handbooks.com/Townace.html
    but there is an error Error 403 - Forbidden
    You tried to access a document for which you don't have privileges.
    Aug 2006
    There are 3 timing marks you need to check, overhead cam shaft, injector pump, and crank shaft. If these 3 timing marks are dead center your engine should start normally.
    Madali na sya start at di na mausok kaso parang sasabog ang makina sa ingay.
    At parang nag a accelerate ung ingay nya. Di namin alam kung saan nangagaling.
    May 2009
    Ginalaw ba fuel lines?
    Nagbleed lang daw ung mekaniko.
    May 2009
    I think that's it....air in fuel lines kaya noisier ang injection. am still not sure though. kelan ba nagbleed? after the 1st or 2nd visit of the mechanic?
    Nung first visit nag bleed ung mechanic. tapos very hard starting baka nga na ubos ung diesel kaya ayaw mapaandar nung isang brother ko, bumili sya ng diesel at kinarga umandar naman kaso hard starting. Ung second visit ng siraniko ni re time ung injection pump pero di nag bleed. kaya cguro nag easy start na eh medjo malapit na ang injection timing nya.
    Nung binuksan namin kasi 2 ngipin ang lampas nya sa markings. Un naman sa camshaft nya parang matulis naman lahat ung lobe pero di pa namin tinatanggal sa head ung camshaft. inikot lang namin para malaman kung may nasirang lobe.. so far ala naman.
    maybe a stupid question but need to ask.. nung bang nagset uli ng timing pinaikot ba uli ng mga ilang beses to verify the marks?
Hard Starting, poor Idling knocking sound after waterpump change
