Results 1 to 20 of 23
    Toyota 2C Normally Aspirated Engine:
    Mga Sir,
    Pinalitan ng mechaniko ung water pump pero kailangan tanggalin ang timing belt.
    Pag kabit nag hard starting tapos maingay di ko alam kung fuel o mechanical knock eh.
    Pero di naman ginalaw ung posisyon ng crank and camshaft eh.
    Ano kaya magadang gawin? Nasira kaya ang camshaft or valves ko?
    Thanks in advance.
    Aug 2004
    Better to have it double-checked to be sure. Even if you don't think you moved anything, you're not sure unless you've checked the alignment of the timing marks.
    the timing is off
    Thansks. Is it the injection timing?
    crankshaft to camshaft index
    Aug 2004
    Quote Originally Posted by t2erns View Post
    Yup. Yun nga yun.
Hard Starting, poor Idling knocking sound after waterpump change
