Results 1 to 13 of 13
    Nov 2006
    mga bossing..
    medyo malakas n consumption ko ng gas from 7-8 city drving ngaun prang 5-6km/l n lng
    questions
    1.any idea kung san maganda magpa tune up ng 2003 revo gas-1.8 manual tranny other than sa casa?
    2.ano maganda engine oil for 1.8 gas engine?
    3.spark plug?
    4.is there any DYI that i can do to improve my consumption?
    thanks in advance...
    Aug 2005
    replace sparkplugs mski ngk lng mski iridium lgay m mlkas p dn yn tlga hehehe check idle m bka more than 800rpm nd ung timing bka nsa 20 degrees ung ibang mekaniko adj nla ng 20 dgrees pra mwla ung tope.
    if proper tune will not do good e nsa age n ng engne un lol. at long run mlakas prin tlga gas na revo mismatch kc ang trnny and rearend ng revo. runng at 90kph onwards nsa 5th gear kna e humihingi p ng isa pa, nppncin mo b sir?
    Nov 2006
    sir ang pinagtataka ko b4 kz am running bout 8-9km/ltr..pero ngaun parang 6-7 n nga lng,,anyway baka nga due for replacement n ang sparkplugs ko..
    try ko din muna cguro gamitan muna ng flux cleaner or carb cleaner (aerosol) gamitin ko pang linis ng sparkplugs..ganito kz nkita ko pinanlinis nung nagpa tune up ung isang tropa ng kotse nya s mekaniko nya
    revo din b ride mo?
    Aug 2005
    B4 may 99 Revo SR MT, gas ako 7-9kms/ltr bhira ung 9 hehe.
    kung may 1yr na plugs mo better to replace it pra mas effcient cya mura lng nmam e
    sir mga around 100php each spark plugs.. try po ninyo replace every 5,000 or 10,000kms.. max na 10,000kms
    Sep 2005
    pertaining to this thread, does tune up only involve the replacement of spark plugs? How about yung tappet adjustment, di na ba kailangan? Mentioned in the manual is "checking of ventilation valves", san po ba to makikita? Pwede ba DIY dito, at paano? Thanks and any feedback is much appreciated.
    Quote Originally Posted by joey View Post
    Tsikot.com Rules and Regulations
    I. On posting
    1) You are expected to post in the proper forum category.
    Each section of tsikot.com has a description which will be your basis on where to post your threads. If the thread you are posting does not belong to any particular category, you will post the said thread in the Pitstop Cafe forum.
    2) You are to post replies legibly.
    SMS shorcuts and randomly alphabetized characters are strictly not allowed. The use of webcuts, however, are acceptable.
    3) You are expected to use the search function before creating a new thread.
    Clutter not only wastes bandwidth but also time. You will find a whole resource of materials and past knowledge on previously discussed topics, if you took some time to familiarize yourselves with the search engine.
    4) Thread titles should be meaningful and concise.
    Again, your time is valuable, and so is mine. Thread titles should already give a hint on what the subject is about. We would all like to get into the meat of the discussion and not mess around with titles such as "Alam niyo ba....", "Saan ang...". Besides, not all people have the luxury of DSL and T1 connections.
    5) You will not post messages that are clearly outside of the stated topic.
    If you feel that you're already discussing something else, by all means create a separate thread for that new topic. You are not to post repeated irrelevant messages or copies of identical messages.
    II. On Behavior
    1) You will respect the moderators and administrators of the forums at all times.
    2) You will not behave in an abusive and/or hateful manner, and will not harass, threaten, nor attack anyone.
    3) You will not use profanity in our forums against anyone, nor post any language or content that is obscene or ***ually oriented.
    4) You have the responsibility to ensure that all your posts contribute to the welfare and good of the community
    5) You will respect other people's right to personal privacy. You will not post any other person's identifying information (including their contact information, and any other relevant information) within the forum but your own.
    6) You will not use these forums to violate any laws nor to discuss illegal activities.
    7) You will not to impersonate any person or entity or manipulate identifiers in order to disguise the origin of any posting, nor collect or store personal data about other users.
    8) You will not post advertisements, chain letters, pyramid schemes, or solicitations, all of which are inappropriate and prohibited in the Forums.
    9) You will, if asked by a representative of the Forums, cease posting any content, and/or links to content, deemed offensive, objectionable, or in poor taste by the staff of the Forums.
    10) Multiple accounts will not be tolerated.
    These rules will take effect immediately.
    Violation of the above will be subject to appropriate action by the tsikot.com Administrator and Moderator Panel.
    The tsikot.com management reserves the right to amend the above rules without prior notice.
    Tsikot.com Administrators and Moderators
    Aug 2005
    Quote Originally Posted by evag View Post
    about tappet adjustment, ang revo ay hydraulic valve lifters na means self adjusting na cya dko lang alam ung diesel kung gnon n din.
    Nov 2006
    i just had my 5k change oil d2 s suking talyer namin,,question is do i still need to go to toyota service center for computerize tune up? bka kz s timig ung prob kya lalo lumakas s gas consumption
    May 2007
    Quote Originally Posted by bengkok View Post
    it would be better sir if you bring it sa casa. it would cost you around 700-800 pesos lang naman. spark plugs lang naman papalitan dyan. at least, you'll be assured na mababalik to specs yung ride mo. ganyan din kasi nangyari sa revo namin before...nawala sa timing... yun pala kailangan na magpalit ng spark plugs. hope this helps
    Nov 2003
    di naman kelangan sa casa just to do the timing. anywhere with a timing light should be able to do it for you.
    Oct 2014
    Aside from Toyota casas, any quality shop you guys can suggest to have Revo engine checked? Napansin kasi na medyo umingay ng konti yung makina. Thanks.
    Oct 2014
    Marikina, Pasig or QC preferred location. Thanks again.
tune up for Revo 1.8 engine
