Results 1 to 12 of 12
    Jan 2008
    guys am new hear lang sa tsikot.my unit is fortuner V 3.0 D-4D ask ko lang kung na experience nyo na ba yung even hot or cold ang engine may tumutunog sobrang ingay parang metal to metal. di nala ko sya sa toyota dasma kaso hindi naman dun tumunog kaya walang nangyari
    ginawa nila.lahat ng pulleys tinangal.lahat check kasama idler bearing pero wala namn dun ang sira.kanabukas tumutunog nanaman. pero ngayon 2 days wala na yung tunog.badtrip nga di mo alam kung kelan ulit tutunog. occationaly po ang tunog nya matining.salamta po!!
    Mar 2007
    sir kung brand new ang d4d unit mo, this noise together with the white smoke you reported previously then candidate for lemon siya, wag tantanan yung dealer
    Nov 2007
    hindi kaya factory deffect sir??
    ilang km na po ba fortuner nyo???
    Sep 2006
    Intermittent faults are difficult to diagnose as these problems sometimes don't occur while being diagnosed. My suggestion:
    1. Discuss your problem with your Toyota service manager,
    2. You may have to leave your Fort with toyota for a few days to give them a chance to see the problem occur,
    3. Don't allow any independent shop work on your Fort if it is still under warranty. This will void your warranty.
    Konting pasensha pa. Minsan, may mga problema na mahirap talaga idiagnose.
    Jan 2008
    pero ngayon po 5 days na di na tumutunog di ko lang alm. kung dahil sa nag change ako ng diesel brand. i switch to shell dati kc sa petron ako ng karga. saka ngayon. napuna ko medyo tumipid sya sa gas pero mas lumakas po yung white smoke nya.plagay nyo po.kailangan na kya i reset ecu? pero since nabili ko unit ko wla syang hard starting problem.or yung sinasabing d4d woes... my unit is 1year&8months. 50250odo.almost 110kms.per day kc po sa realstate kmi.cavite,calamba,makti route ko.salamat.
    Z-AUTOEQUIPT,
    >>Have you changed settings before? If yes why?
    >> Does it sound like pump na walang nasisipsip? When do you usually hear it? High speed? Hi/lo rpm?
    Nov 2007
    obserbahan nyo na lang po ulit baka nag kataon lang
    Jan 2008
    fully stock po walang nilikot. & complete po lhat ng pms ko.ang tunog nya eh yung napakatining tapos pag ni rev mo ng ni rev. biglang mawawala kasabay ng tunog na parang airbrake na.biglaan lang tala yung tunog nya during mag pa pa-park ka o kaya after starting hot or cold ang engine.pero ngayon ok naman sya 5days na di natunog...hoping na di na talaga sya tumunog dami na ksi binaklas na mga pulleys nakakaawa na sasakyan...
    Nov 2003
    leave it with them for a while para makita or bring it to toyota while it is noisy para makita nila.
    Sep 2006
    Quote Originally Posted by Z-AUTOEQUIPT View Post
    How is your Fort?
    Naayos ba ng Toyota ang problem mo?
    What was the fix?
    Please advise. I would like to learn from your experience.
    Jan 2008
    as of now po.ganun padin di parin sya tumutunog naka 1000km na ako.since na nag pa service ako.talagang araw araw ko ginamit fort ko almost mag 2weeks na pero ayun ala parin tumunog,naghihinayang lang ako sa ginawa sa casa ksi na damage nila yung mga turnilio ng mga pulleys.tapos di naman nila nagawa.ngyn po di ko po titigilan fort ko baka maylumabas pang sira atlis covered pa ng warranty...salamt dieseldude dami mo natulungan dito sa forum..
    Sep 2006
    Mabuti naman at hindi na umulit. Pero sa experience ko, maaring bumalik ang problem mo kasi hindi naman nakita ng Toyota ang source ng engine noise.
    Baka naman naayos na nila ang problem nung nakaraan, pero hindi lang nila sinasabi sayo and correction na ginawa nila?
    ngyn po di ko po titigilan fort ko baka maylumabas pang sira atlis covered pa ng warranty... Korek ka jan. Also, ask the Toyota service advisor to take note of your complaint so that they will repair it free of charge if the problem shows up again after the warranty period.
    Salamat din sayo. And please don't forget to post the correction in the future. Just as I would like to help, I would also want to learn from your experiences.
Toyota Fortuner v 3.0 D-4D engine noise sobra!!!
