pronto is sa service road bandang sucat ata. on the right side if you're comming from makati going south.
for a 2004 Honda City 1.3 iDSI, what viscosity should you recommend?
and where in Fairview, or atleast near Fairview can i buy RP?
mga sirs, off-topic question po (sabay ko na rin).
what viscosity is recommended for my car? a/t '99 civic vti po.
probably next weekend or maybe the next after, im planning to have my car changed oil na kasi. before i read this thread, i am thinking of using mobil1 synths (endorsed by some friends who uses it). then i read about this royal purple brand and it strikes me as a candidate also, mukhang madaming napaligaya ito, hehe. price-wise, alin po kaya ang mas mahal between mobil1 & royal purple? are they relatively close in terms of performance? TIA...
CaRGirL, use a 10w30 viscosity oil for your engine.
hakkinen, use 10w40 for your engine. m1 full syn oil is around 7-800/liter, RP is 500/qt.
sir speedyfix newbie here ask ko lang kung anong oil ang maganda sa corolla 96 gli.d ko alam kung anong oil ang ginamit sa kotse ko.second hand kaya d ko alam kung anong gagamitin brand and viscousity..tnx ng marami..bale due na rin for change oil 81k na ang odometer reading.tnx
mga sir,
up ko lang po sana kung meron nagbebenta ng RP sa Pasay or Cavite area?
salamat po mga sir
mga sir mag ordinary oil nlang po cla plus friction buster oil additive mas mura sa synthetic and much more ung protection sa wear and tear
eto po site nila www.bfteft.com
or contact nyo po ako 09219148053, salamat po
for a corolla a 10w40 is perfect. expecially since medyo mababa pa milage mo.
i'd never use additives. if your oil is good enough you won't ever need it and it's a useless expense.
you should be using a 5w30 or 10w30 oil on the vios. it says so in your manual.
naku, kakachange oil ko lang last saturday sir...d bale sa next change oil ill use 10w30.. pero okay kaya ang castrol? or may marerecommend ba kyo na oil aside from RP? thanks
