Results 1 to 10 of 10
March 12th, 2015 09:18 AM #1
hey guys base sa opinion nyo o kaya sa mga gumagamit ng FS oil. normally, ang change oil ay every 6 months o kaya mileage na 10k which ever comes first . pero mayron satin gaya ko na less than 10k ang mileage pero nag- elapse na ng 6 months so mapipilitan tuloy tayo mag change oil kahit wala pa sa mileage na 10k.
eto ang tanong ko lang, recommended ba natin magreplace lang ng OIL FILTER at ibalik muli ang nagamit na nang used oil galing din kanina sa makina? tapos top up or dagdagan na lang ng NEW OIL with same viscosity para sa magiging tamang sukat ng oil sa dip stick?
March 12th, 2015 11:07 AM #2
di ko makita logic.
i drain mo yung gamit na fully synthetic oil, palit filter tapos ibabalik ang used oil.
so it means, lahat ng dumi ng lumang oil ay ibabalik mo. bago lang ang filter.
if this is the logic, why not use a lower oil grade and change your oil and your filter both at the same time para parehong malinis?
parang dialysis yan..... yung maduming dugo ay ibabalik mo sa loob ng katawan mo, parang balewala.Last edited by 1D4LV; March 12th, 2015 at 11:11 AM.
March 12th, 2015 12:28 PM #3
actually sabi lang sakin yan kaya post ko dito. bro, same din tayo ng logic, ito rin nga ang tanong ko sa kanya same as your "lahat ng dumi ng lumang oil ay ibabalik mo. bago lang ang filter" sagot nya at least yung dumi sa lumang oil nabawasan at nafilter ito at yung dumi napunta sa oil filter. hehe
March 12th, 2015 02:06 PM #4
ganun pa din yun, imho.... aside from the dirt, degraded na yung oil, since gamit na. sayang lang yung cost ng oil filter pag ganun.
March 12th, 2015 02:51 PM #5
at 6 months and even 5k mileage but everyday usage dahil sa crawling traffic. I would think that the additives are already used up. hence there is a time based computation. oil is necessary.
kung isip nya na filter na dirt by the old filter....sounds like a jeepney driver lol. no offense sa otherwise
March 12th, 2015 05:33 PM #6
Sa casa ko, tinitingnan nila mileage, hindi months. At yung TS, parang pahihirapan mo lang sarili mo kung mag drain ka then ibabalik mo rin pala.
March 12th, 2015 05:42 PM #7
Mabuti pa hindi na alisin oil, yung oil filter lang palitan and then top-up. Again 1y lang advisable na gamitin ang oil kahit FS pa. After noon kahit 1,000kms lang tinakbo dapat palit na. So better use mineral oil and palit na lang every 5,000kms or 6 months whichever comes first.
- Jun 2005
- 3,774
March 12th, 2015 06:32 PM #8kung susuot ka lang din naman sa ilalim para magpalit ng oil filter, might as well palitan mo na din langis.
almost same effort lang naman. konti lang nadagdag sa pagod pero mas maganda sa makina
- Oct 2009
- 2,271
March 13th, 2015 03:19 PM #9ano ba maganda .gagamit ako ng FS oil every day gamit ko tsikot from laspinyas to malate.balikan.tapos mag change oil ako every 10k kilometers
gamit ko kasi castrol oil lang 830 pesos tapos 150 filter saka 150 labor,un nga lang every 5k nag change oil na ako..
ano ba mas okey
ano ba mas okey
March 13th, 2015 03:44 PM #10
naka mineral oil ka lang ngayon bro and iniisip mo mag pa FS?
imho, depende yan sa iyo.... kung naka FS ka and 10k kms ang interval, ok lang yun. but do not expect that it will change your fuel consumption significantly. kung mineral oil, ok lang din, basta palit ng 5k kms. basta if you do an oil change maski anong langis gamit mo, palit filter..... kung palit filter, palit oil.
ako, semi-synth gamit ko... palit every 5k kms.
ang point ko lang naman is hwag magtipid....naranasan ko na mag change engine dahil sa sludge (2nd own yung oto). mas mura pa din ang regular oil change intervals kesa magpalit ng makina o magpa overhaul.
Xiaomi E-Car
