Results 1 to 10 of 11
- May 2009
- 3
September 19th, 2010 08:10 PM #1Hi Tsikoteers,
Mga sir's newbie po ako d2 and tanong ko lang sana kc ung timing belt nang kotse ko (Corolla '98 GLi M/T - 2nd hand owner po ako) may punit/hati and plano ko na sna palitan. May ma-recommend ba kyo na shop d2 sa Cainta near Marcos highway na okay at hnd mahal sumingil. And kelangan ko na rin kc pa-change oil. Anong viscosity and brand kaya pwde sa ride ko? And lastly, san kaya pwde mag pa-tune up? Salamat!
Cooldude,
- Dec 2009
- 304
September 19th, 2010 09:07 PM #2
September 19th, 2010 10:00 PM #3
yung tune up at change oil ay makakapghintay broTS, pero yung timing belt mo ay hindi, papalitan mo na kaagad ASAP; dahil kapag naputulan ka ng timing belt habang natakbo ang auto mo ay di ka na magiging cooldude...
dahil iinit ang ulo mo sa gastos....
September 20th, 2010 04:45 PM #4
try to replace the belt first if you dont have the budget then do the others later
- Jul 2003
- 573
September 21st, 2010 03:36 PM #5baka naman fan belt ang nakita mo na may hati. yung timing belt kasi eh may cover at di mo basta masisilip, unless tinaggal na ang cover niya.
- May 2009
- 3
September 28th, 2010 01:46 PM #8*tip_tipid / billnomoney : fan belt nga pala (sensya na po bago lng eh! ) kaya ayun pinapalitan ko na ung tatlong belt.
*Marz : nagpunta ako sa caltex dun ako nagpa-change oil (Havoline 20W-50 nilagay nila) okay lng ba un? sbi nya kc ok lang un. Bka pagbalik ko pa tune-up naman ako.
Tanong ko lng kc napansin ko na parang maingay ung makina sabi nung sa caltex baka ung injection daw dapat palinis or ipa-check. Hnd daw nila kaya gawin kaya sa ibang shop daw dapat dalhin. Mga sir's may marecommend ba kayo na mekaniko/shop na malapit d2 samin (Sta.Lucia-Cainta/Marcos H-way)? Thank you sa mga reply at mag-rereply.
- Jul 2010
- 28
September 28th, 2010 05:11 PM #9
mom loved the Ten Commandments. i also liked the two actors there, yul brynner and edward g...
Traffic!
