Results 1 to 14 of 14
    Mga sir newbie :newbie: lang po ako about sa sasakyan, tanong ko lang po kung magkano cost estimate in changing my timing belt? Pwede ba siya magawa sa bahay o kailangan siya dalhin sa talyer nang mekaniko po mismo? Mga ilang oras po o araw ang pagpapalit nito?
    Maraming salamat po in advance and more power....:rockon:
    I don't know how much the timing belt exactly costs, but it depends per car. I know its starts around 5k+labor+++ depends on the car. If I'm not mistaken. I just recently had my car overhauled because the timing belt broke (valves got bent, serious internal damage).
    You should have it fixed with a mechanic. I know Rapide changes timing belts and it may take a while. Not a 1-2 hour job. It takes a while before they can get into the timing belt. They gotta dig deep and remove a lot of stuff.
    Ito dapat kasabay ng timing belt change, usually 800 - 1.2k pesos labor nyan.
    timing belt
    tensioner bearing
    waterpump
    camshaft oil seal
    crankshaft oil seal
    Maraming salamat po sir sa reply. Ang sa akin naman po di pa naman siya putol kaya lang gusto ko na siyang palitan dahil second hand ko po nakuha yung '97 Honda City ko po and di ko po alam kung kelan po napilitan nang previous owner yung timing belt (my bad di ko tinanong ).
    To avoid much bigger cost pag naputol yung timing belt gusto ko na po sana siya palitan preventive measure na din kumbaga.
    Mga sir any feedback of how much the installation of new timing belt will cost me, kasama na din yung labor doon po???
    Maraming salamat po and more power....
    Quote Originally Posted by boggs.m18 View Post
    opinion lang, dont go to rapide... dami na horror stories diyan.
    sir wave, punta ka sa pasay and look for dondon, mura lang labor sa kanya. siya nagpalit ng timing belt ko then mura pa pyesa sa car power. palitan na lang lahat ng seals and water pump para isang bukasan na lang.
    Quote Originally Posted by archie123456789 View Post
    Noted ko po yung rapide sir dami ko nang nabasa sa mga thread dito about their horror stories with rapide... Maraming salamat sir
    Ahhh kaya pala ang daming papalitan sabay-sabay para isang bukasan na lang nang makina... now gets ko na, maraming salamat sir baguhan pa lang kasi po ako pagdating sa kotse po eh.
    Normally mga sir how much it will damage my pocket if all of this will be replaced???
    *double post*
    Never knew about the Rapide horror stories. Just noticed their service menu that they can. Haha! I had mine changed in AutoPlus (but it was a major overhaul, so i don't know if they would accept a timing belt change service alone.) I'm just pretty confident of what they can do to a car since they're well known in the local automotive industry.
    Thanks for the heads-up though!
    Nov 2006
    sir we have exactly the same type of car. AT nga lang sa akin, ewan ko sa yo. about a month ago nagpalit ako ng timing belt eto gastos ko:
    timing belt orig-1,100 nisparts, banawe tel.7421531 look for arnel
    water pump japan-900 nisparts
    tensioner bearing japa-650 nisparts
    crank/cam shaft orig-250 each nisparts, banawe
    labor-1,200 sa kaibigan, 1,800 sa speedyfix, 3,00 sa honda spa
    it took half the day for the labor sa kaibigan, 6hrs daw sa speedyfix, whole day sa spa
    Quote Originally Posted by lancer5790 View Post
    sir AT din sa yung kotse ko po....
    sir ask ko lang po sa iisang store niyo lang po ba ito binili lahat???
    Maraming salamat po sa feedback...
    Nov 2006
    Quote Originally Posted by wave105 View Post
    yes, sa nisparts lahat. nagcanvassed din ako sa mga ibang stores but incidentally i felt comfortable most with nisparts in terms of price, reliability of orginal parts, accessibility and some tips from arnel...
    Oct 2008
    sir archie,
    san sa pasay si dondon? taga pasay din ako. ang tagal ko ng naghahanap ng maayos at honest na mekaniko.
    may contact no. ka po ba ni dondon? papacheck ko po kasi yung cooling system ng revo sr diesel namin.
    maraming salamat in advance!
    May 2013
    hi guys,
    anong brands ba ok na timing belt for honda civic vtec 3? price range? thanks!
    Aug 2011
    Quote Originally Posted by gutz_3110 View Post
    hi guys,
    buy an original timing belt from honda.
    Posted via Tsikot Mobile App
Timing Belt Replacement
