Results 1 to 5 of 5
December 30th, 2003 07:14 PM #1
My temperature gauge rises when the car (Mazda) is just idling. Btw, I only have water in the radiator. There are no leaks whatsoever.
Should I flush the existing fluid, add coolant and top it off again with water? Or can I just drain some of the water, add the coolant and top it again with water? (That's the instructions from the coolant I bought)
Thanks
December 30th, 2003 07:36 PM #2
Even if you only have water, your engine shouldnt overheat. Are the aux fans working?
December 30th, 2003 08:09 PM #3
Mas maganda kung palitan mo na lahat ng laman with a 50/50 mix. Check mo muna kung maganda ang pihit ng aux fan mo saka kung ok pa ang water pump mo. How long have you been running it without coolant? Baka stuck-up na kasi (coolant provides lubrication for the water pump).
SiRaNeko
- Jan 2003
- 973
December 30th, 2003 09:14 PM #4suggestion lang po.
why not try to drain the water n change it with new water. bka yung water sa loob ng radiator e fully depreciated na. if that doesnt work then try water wid coolant.
Tsikot Member Rank 5
- Nov 2003
- 3,849
January 3rd, 2004 10:25 AM #5before you drain the radiator, check the aux fan. also check the thermostat and thermoswitch to be sure they are functioning. kung barado or sira na yan sure ka na magooverheat.
Kami dati naglalagay ng chain lock ng motor or bike. Iba nakita ko literal na kadena at padlock.
