Results 1 to 20 of 30
    Aug 2005
    do you switch your engine right away, or wait for a few second to a minute for the oil to settle down?
    I wait for the turbo to cool down.
    Jun 2004
    I just switch off the engine right after parking, usually I turn off the aircon, headlights, radio then engine.
    I let the engine idle for a couple of minutes kahit wala akong turbo.
    Dec 2003
    really? so its really recommended to idle for a couple of minutes on a diesel ride such as the D4D turbo?
    May 2005
    Quote Originally Posted by OTEP
    sir otep,
    wala kasi turbo ride namin ....may gauge ba ito para ma notice ko kung nag cool down na or doon sa sinasabi na vacuum gauge
    sorry zero talaga sa turbo
    For vehicles with turbo, it is mandatory to allow the engine to idle for a minute or two before shutting it off. This allows the turbo to cool down properly.
    For non-turbo vehicles, is there any advantage to letting the engine run for a while before turning it off?
    Dec 2003
    even if the engine rarely reaches 2.5k rpm? delicate pala turbo diesel engines
    May 2005
    same question here... for non-turbo vehicles, is there a proper way of switching the engine off?
    ako kasi, i rev the engine muna before turning it off eh... :D
    Dec 2003
    Quote Originally Posted by izzy
    thats a waste of gas afaik..
    Quote Originally Posted by BlueBimmer
    Yes, because the turbo is spinning far more faster than 2,500rpm. Same applies to turbocharged gasoline engines.
    thats a no-no.besides wasting gas, i read that it has detrimental effects connected with sludge...or something to that effect.
    May 2005
    Quote Originally Posted by GlennSter
    ah ganun ba?? better start not doing that, then...
    Aug 2005
    reply pa kayo!
    That practice harks back to the day of old-school carb engines. Though I don't really get the point of doing it nowadays. Even newer carb engines can get by without it.
    May 2005
    sabi pa nila noon araw..
    since nag rev ka nag charge ang ang battery mo
    comes from alternator sabay click off ng ignition switch
    mura pa kasi gas noon araw
    IMO, pag may turbo, idle for at least 1 to 2 minutes, for long drives, at least 3 to 5 minutes. Pag walang turbo, turn off the engine right away, don't rev, sayang lang gas or diesel.
    Sep 2004
    dont rev ... sabi nga sa previous posts, sayang lang gasolina.
    after parking, i do the following: check handbreak (nakalimutan ko dati and when i came back sa car ko it apparently rolled slowly onto a van .. ouch!), turn off radio, turn off lights then turn off the engine. i usually turn off the a/c more than 3 blocks away from the house.
    Aug 2003
    yup.. ok lang to turn the engine right away. pero madalas parang automatic na yung paa ko to rev before turning off the engine.
    For non turbo engines, you can turn it off right after shutting off the a/c, radio, etc... No cool down needed here. Idling and revving will just waste gas usually.
switching off the engine
