Results 1 to 13 of 13
    Mar 2007
    Sir ano ba ang mga parts to check kung sa unang click ay umiistart ang engine then after 1 to 2 mins unti unting bumababa ang rpm at tuluyan ng namamatay tapos pag inistart uli ay puro crank na lang at ayaw na tumuloy?
    Could it be the high tension wires? Paki-advise naman po mga gurus kung may nakaexperience na sa inyo ng ganito at ano ang naging solution?
    Ride is 92 honda hatchback. TY
    I post mo muna make and model ng car mo.
    Feb 2009
    Quote Originally Posted by CarPainter View Post
    check the basic items first, check the fuel volume and quality, check the fuel pressure, check the fuel filter for restriction. if it stalls after around two minutes of engine run time, chances are the fuel system or the exhaust system is at fault.
    Mar 2007
    Sir, saan po banda nakalagay ang fuel filter ng honda hatchback? Chineck ko po ang engine pero wala akong makitang fuel filter, unlike sa nissan or toyota na makikita mo agad ang fuel filter pag binuksan ang hood.
    Ano po ba ang kadalasang inaayos kung exhaust system ang problema? TY
    Feb 2009
    the fuel filter is underchassis adjacent to the fuel tank
    check for kinked tailpipe, bent exhaust pipe, dented of flattened exhaust pipe and check for catalytic converter clogging. you can test this using an engine vacuum gauge. with the engine warmed up, snap the throttle open and watch the vacuum drop, then hold the throttle at around 2000 rpm and watch the vacuum gauge hold steady around 15 inches of mercury. if the vacuum drops while you hold the engine speed at 2000 rpm, the exhaust is more than likely clogged
    Jul 2003
    carb type ba ito? kung oo, check the fuel delivery system. nabanggit na yung filter. change it.
    kung kaya ng resources mo, drain mo yung fuel tank mo, have it cleaned and refill with new fuel.
    then yun carb, i-check mo kung may pumapasok na gasoline. kung meron, baka dun mismo sa loob ng carb ang problem. ibig sabihin ipagawa mo sa espesyalista.
    Mar 2007
    Sir, kahilera ba ng driver side un fuel filter or passenger side? Umilalim ako para silipin sana, hinde ko malocate kung saang side ng fuel tank un filter...plastic na white din po ba ang itsura nun?
    Mar 2013
    haha same prob here .. intermitent cold star problem.. same model same issues. started last feb. lahat ginawa ko na change> oil, oil filter, fuel filter, spark plugs, had my gas tank drained, changed to higher octane gas,.. every now and then bumabalik pa din. although na lessen ung topak. bumabalik lang sya pag may importante ako na lakad hehe. Ang work around ko pag nag loko ung oto is i leave it for 10 to 15 minutes then saka ko sya start ulit. then normal na sya the whole day . pero ung technique ko sa second start (after waiting 10 to 15 minutes), press the accelerator down to the floor then start the engine. pag nag start na sya ulit stable na rpm nya. to this post 3 weeks na hindi nag loloko. But im sure the problem is still there. Ang hindi ko pa ginagalaw is ung mechanical fuel pump, carburetor(overhaul), and ung high tension wire.
    kung di mo makita fuel filter. dalahin mo sa suking gas station na may lifter petron o shell. white na plastic part sya na makikita mo sa ilalim ng driver side bago mag gas tank. 100 pesos lang un... sa kanila mo na papalitan sabay mo na din change oil kung hindi mo pa nagagawa.. kaso mahirap maghanap ng fuel filter nyan eh. kung meron ka man makita, hindi kasya sa bracket. ung akin ginamitan na lang ng lock tie.
    Mar 2007
    Quote Originally Posted by pitbrad View Post
    Hehe, hinde naman kaya isa din to sa mga sakit ng eg carb hatch (aside from the bulutong sa bubong) . Thanks sir pitbrad.
    Mar 2013
    pwede.. kutob ko sa carburador na nga yan eh.. pero palit ka na din fuel filter. mejo mahirap i DIY yan. ung location kase sa ilalim. advise lang kung ikaw mag papalit fuel filter, buksan mo muna gas tank and ingat sa sirit ng gas sa mukha mo. ung tension madale lang plug and play lang ika nga. take a picture of your current plug before taking it off para may reference ka. o di kaya lagyan mo masking tape at numberan mo. post mo kung naayos mo problema via tension wire replacement. unleaded ba gamit mo na gas?
    Mar 2007
    Yes sir, ipapakabit ko na lang sa nearby gasoline station yung fuel filter. Ang concern ko na lang po ay kung oks lang ba na hinde OEM ang ipalit kong HTH at fuel filter?
    Unleaded po gamit ko. TY
    Mar 2013
    fuel filter ok lang replacement, mahirap maghanap OEM nun para sa hatch, and mura lang replacement so pwede ka magpalit every change oil. HTH mas maganda oem. pero kung wala pwede din naman ung mga japanese replacement. ung akin replacement lang matagal ko na gamit. sinira kasi 5 years ago nung mechanico na tumingin sa oto ko, hinatak ba naman sa wire.
    eto link para makita mo itsura ng fuel filter ng hatch.
    Fuel filter Civic EG3 ADH22324
    may chance na hindi mag fit sa bracket ung replacement so gawan na lang ng paraan. ung akin tinangal ung bracket at ginamitan ng tie lock. pero kung makakahanap ka ng kasya sa bracket mas maganda.
    Mar 2007
    Note sir pitbrad and thanks also for the pic provided.
Umiistart then unti-unting namamatay engine
