Hi guys. I'm a newbie with cars and this site has greatly helped me since i joined. Last week, i availed of the Honda Homecoming promo where you can bring your 2nd Honda and have it thoroughly checked. I brought my 2nd hand 1997 Honda Civic VTI A/T to Honda, Pasig. After the free 112 points check-up, they gave a list of spare parts that need to be replaced right away. However, if I am going to have it fixed in the casa, I could not afford the quotation. So I decided to just buy the spare parts outside and have it replaced also outside. I would just like to ask Honda owners if you know of reliable shops and auto supply stores where i can buy replacement parts? I listed the needed parts below. Feel free also to post here if you are aware of the price for the sake also of other tsikoteers. Thanks a lot.
For immediate replacement:
Oil Pan Gasket
Front crankshaft oil seal
camshaft oil seal
rear crankshaft oil seal
oil pump o-ring
manual valve oil seal
torque converter o-ring
distributor oil seal
valve cover gasket
lock up sound valve o-ring
P/S belt
Front L/R Shock unit
To be replaced at a later time:
plate light bulb
brake light bulb
wiper blade
upper/lower hoses - cooling
by pass hose/ heater hose
joint return hose P/S
brake pads
LH trailing arm bushing
Thank you once again for your replies.
