Results 1 to 10 of 12
- May 2004
- 903
November 20th, 2010 08:46 PM #1We had our car compression tested in two reputable shop
1st shop reads
175.120.175.175
2nd shop reads
250.225.250.250
The car is 6 years old and 100T plus km reading
This two shops are good and reputable dito sa site so I won't mention the name
Baket magkaiba ng reading? is there something wrong with the car?
November 20th, 2010 09:04 PM #2
Obviously cylinder 2 has either loose piston rings or leaking valves.
The simple test (i think) is to remove the cylinder head, turn it upside down and pour water on the valves (of cylinder 2) and wait. If water drains, then it's a leaking valve. If water doesn't drain, it's faulty piston rings.
As for the readings, I don't know if the difference is still within tolerance though.
- Jul 2003
- 573
November 20th, 2010 09:23 PM #3did the two shops mentioned here used the same setup and procedure to get the readings? did they use identical compression test equipment?
but one thing is obvious, both have low readings shown in cyl 2.
- May 2004
- 903
- Jun 2010
- 76
November 20th, 2010 11:04 PM #5pasado naman ang compression mataas naman ang result..dapat pinakunan mo ng wet type..para sa akin wala problima yan reading mo ng compression.madalas ganyan yan din ang nakukuha ko na reading basta wag lang sobra baba ng reading kasi kung may problima ka sa c ompression palyado na ang andar ng engine.yan ang pagkakaiba ng sira ng oil ring at piston ring..pagnasira ang piston ring compression palyado ang andar..pag nasira ang oil ring maganda ang andar pero may white smoke..tnx..some lang ng reading mababa yun cyl.2..ok pa yan..
THE AUTO SPECIALIST
- Mar 2006
- 607
November 21st, 2010 07:21 AM #6based sa 1st readings , marginal ang #2 cyl. ok pa yan .
the best sana kung meron shop dyan na gumagawa ng ELECTRONIC COMPRESSION TEST , and that will be done from the battery .
this is pinpoint diagnostics procedure , no guessing and it only takes few minutes without touching the engine.
- May 2004
- 903
November 23rd, 2010 08:43 AM #71 of my concern is pwede kaya mali yung pag compression test ng isa sa dalawang shop? Or should I get an 3rd opinion?
November 23rd, 2010 02:33 PM #8
sorry OT:
ask ko lang po kung magkano magpa-compression test for 1.6L 4 cylinder engine?
- Apr 2009
- 1,902
November 23rd, 2010 11:46 PM #10
