Results 1 to 12 of 12
    May 2004
    We had our car compression tested in two reputable shop
    1st shop reads
    175.120.175.175
    2nd shop reads
    250.225.250.250
    The car is 6 years old and 100T plus km reading
    This two shops are good and reputable dito sa site so I won't mention the name
    Baket magkaiba ng reading? is there something wrong with the car?
    Quote Originally Posted by 1997 View Post
    Obviously cylinder 2 has either loose piston rings or leaking valves.
    The simple test (i think) is to remove the cylinder head, turn it upside down and pour water on the valves (of cylinder 2) and wait. If water drains, then it's a leaking valve. If water doesn't drain, it's faulty piston rings.
    As for the readings, I don't know if the difference is still within tolerance though.
    Jul 2003
    did the two shops mentioned here used the same setup and procedure to get the readings? did they use identical compression test equipment?
    but one thing is obvious, both have low readings shown in cyl 2.
    May 2004
    Yap but the 2nd is with in 10% tolerable level... Tama ba ako?
    Jun 2010
    pasado naman ang compression mataas naman ang result..dapat pinakunan mo ng wet type..para sa akin wala problima yan reading mo ng compression.madalas ganyan yan din ang nakukuha ko na reading basta wag lang sobra baba ng reading kasi kung may problima ka sa c ompression palyado na ang andar ng engine.yan ang pagkakaiba ng sira ng oil ring at piston ring..pagnasira ang piston ring compression palyado ang andar..pag nasira ang oil ring maganda ang andar pero may white smoke..tnx..some lang ng reading mababa yun cyl.2..ok pa yan..
    1st shop reads
    175.120.175.175
    2nd shop reads
    250.225.250.250
    based sa 1st readings , marginal ang #2 cyl. ok pa yan .
    the best sana kung meron shop dyan na gumagawa ng ELECTRONIC COMPRESSION TEST , and that will be done from the battery .
    this is pinpoint diagnostics procedure , no guessing and it only takes few minutes without touching the engine.
    May 2004
    1 of my concern is pwede kaya mali yung pag compression test ng isa sa dalawang shop? Or should I get an 3rd opinion?
    sorry OT:
    ask ko lang po kung magkano magpa-compression test for 1.6L 4 cylinder engine?
    Apr 2009
    Quote Originally Posted by aejhayl17 View Post
    sorry OT:
    Around P200 po kay speedyfix
    Quote Originally Posted by isa1023 View Post
    200 lahat lahat na po? makapag avail nga sa next visit ko sa kanya
    Hi Malamang bro mali ung 2nd reading, baka mahina na ang spring ng gauge nun.
    Kapag nasa 200 + ang compression cgurado mag piping ang makina sa unleaded gasoline.
    Nov 2003
    the compression can change from shop to shop. i wouldn't really worry about it since it might be different procedures and testers. what's obvious from both tests is that there's a cylinder down on compression so that's what you should be looking at.
compression test 2 shop, 2 different reading
