Results 1 to 10 of 21
March 24th, 2004 01:46 PM #1
hi guys. a friend of mine owns a mazda 323 familia 98 model. medyo na nagkakaproblema na siya dahil bukod sa laklak ng gas e kapag nagpepreno e namamatayan pa ng makina. ano kaya ang problema nun?
thanks!
March 24th, 2004 02:04 PM #2
ahh... the ever present idling problem of the mazda familia...
i've used to experience the same problems but was later cured by a fuel pressure regulator. caloyski also suffered the same problem was it magically disappeared one day.
even the service mechanics are at a loss on how to cure this permanently. they can fix this but after a few days it'll come back.
you can try these quick fixes:
- computer reset
- clean the throttle body
- change your spark plugs to cold ones
- tune up
- Nov 2002
- 194
March 24th, 2004 03:56 PM #3may have something to do rin sa electrical kse pag nag-brake ka, you consume additional electrical load then sabayan mo pa ng pag-on ng aircon/auxiliary fan. i remember before yun friend ko nagpalagay ng relay sa aux fan para ma-minimise yun fluctuation sa power pag nag-on yun aircon.
March 24th, 2004 05:28 PM #4
when you press the brake kasi, the computer will lean out the fuel mixture. kung medyo out of tune na makina mo, that might be sufficient para mamatay yung makina.
try nya muna tuneup. if that doesn't work, adjust niya idle (lalong lalakas yung laklak ng gas though...)
Tsikot Member Rank 3
- Nov 2002
- 1,773
March 24th, 2004 06:10 PM #5try mo dalhin sa signet sa commonwealth. dun ko pinagawa yung similar prob ko dati e (although balintawak autocenter pa sya nun) at naayos naman. di na bumalik yung problema kahit once o twice a yr lang ako pa change oil/tune up.
March 25th, 2004 08:03 AM #6
ok. i'll have it relayed to my friend. let all modesty aside, barubal kasi gumamit yun e.hehehe. kaya ayun binibigyan sya tuloy ng problema ng auto nya. ika nga "Take of your car, your car will take care of you". by comparison, let me quote sir mazdamazda, mas bata pa ang ride mo kesa dun (kilala mo ito). meron pa ngang nagiging problema yun e, sa electricals naman. yung ribbon cable underneath sa steering column. wala syang busina at the same time yung airbag non-functional na rin. sayang talaga yun. "crush" ko pa naman yung 323 nya.
March 26th, 2004 06:40 AM #7Originally posted by mazdamazda
- computer reset
- tune up
- computer reset
I have the same problem and tried the other fixes, but it didn't work. Sabi ng mechanic me problem pa din sa idle, suku siya.
Work around namin ng mechanic (very nice person) ni speedyfix is to make the idle more aggressive (1k). Although 1 thousand petots/ 280+km per week gastos ko sa gas.
March 26th, 2004 09:32 AM #8
ako weird ng timing ko...
pag umaga... ok... pero pag gabi... medyo nag didip ang idling kapag nilagay mo sa neutral ang clutch... then unti unti ulit siyang tataas...
pero not to the point na katulad dati na nanginginig ang makina tapos namamatayan...
quick fix? change your plugs to bkr6e... yung ang cold plugs ng ngk... kasi ang stock is bkr5e...
computer reset? um, tanggalin mo lang ang battery terminals then press the horn then ibalik mo ulit... ayun na yun...
March 26th, 2004 02:59 PM #9
cleaning the throttle body helped solve most of the PTP guys' idling problem..yung sakin weird talaga...im now experiencing it again...labo.. try bringing it to kia commonwealth/prince motors..the service manager there is well-read with the mazda familia
- Nov 2002
- 1,773
March 26th, 2004 04:05 PM #10wierd a. is that prob common with gen2 only? or pati yung gen2.5? akin kasi gen2.5 e. once naayos sya, di na sya bumalik. di ko talaga alam kung anong ginawang ayos dun. oh well, nakatsamba cguro ako. hopefully maayos din sa lahat. good luck!
If that's the case, then hindi rin pala lahat ng nakaka-afford sa kanila ay hindi frugal mag-isip...
2021 Toyota Land Cruiser LC300
