Results 1 to 10 of 10
- Feb 2007
- 79
September 2nd, 2010 02:39 PM #1Good day mga tsikoteers!
May nabili ako ulit ng nissan lec (94 model carb type) last month. Last week ko lang napansin na yun pang 3rd na sparkplug (from oil filler cap) eh wala na palang nut. meaning di na sya mapipihit para mapalitan. Ano kaya best way? Pwede kaya ito gamitan ng easy out tool? Ayoko muna sana kasi ipatanggal ang head.
Thanks in advance po!
September 6th, 2010 04:06 AM #2
kung thread ba ng sparkplug hole na kalbo ,,baba ang engine for re-threading.
- Feb 2007
- 79
September 6th, 2010 04:20 PM #3
September 6th, 2010 04:31 PM #4
I done this before & it work ,,,pasilsil using plat screw driver or spot welding .
September 6th, 2010 05:07 PM #5
Patignan mo muna sa machine shop . Humingi ka ng advice kung paano tatangalin ang spark plug sa ganoon kundisyon ano mainam gawin mas alam nila ito . Suggestion ko lang .
September 7th, 2010 05:15 PM #6
at baka pag natangal mo na yun spark plug ay ibang problema nakatago ! suprise !
- Feb 2007
- 79
September 7th, 2010 05:39 PM #7
September 7th, 2010 11:12 PM #8
ako rin !,,, this can be happend if improper tools used or sadya to hide something.
- Feb 2007
- 79
September 8th, 2010 08:50 AM #9ok na ang spark plug. natanggal ko kagabi. natakpan lang pala ng dumi ang hex nut. palibhasa na-stuck ang sasakyan.binabaran ko kasi ng wd-40 tapos yun kinakabitan ng hi-tension wire eh dinikitan ko ng flat na screw driver then pinukpok ko ng dahan dahan until lumubog na nag konit ang screw driver at napihit ko unti unti ang spark plug. inexpect ko na ang mga dumi kaya vinacuum ko muna. pagtanggal ko ng spark plug, dun ko lang narealized na nandun pa din pala ang hex-nut nya. natakpan lang ng napakaraming dumi. . ok na sya ngayon. running smoothly na ulit.
high idle RPM at engine start
