Page 2 of 2 FirstFirst 12
Results 21 to 28 of 28
    Mar 2005
    #21
    if the noise comes out when you switch the key to on position. dont start it. pop the hood and check it out. if its the aux fan. kita mo na ang problema. pag hindi na lumabas di ok na.
    Feb 2005
    #22
    Just to give you update about my car's problem. It has been a month since I reported the situation and kagabi ko lang natsambahang makita yung problem - the Engine/Cooling fan.
    Last night, when I tried looking for another parking slot (kapapark ko pa lang nito), I tried to start again my car but nung nakaset pa lang sa ON(II) yung susi ko (di pa nagstart), may umugong na sa kotse ko. So I immediately opened the hood and yun nakita kong umaandar yung fan at ang ugong/ingay nya.
    Normal lang kaya ito-(yung pag-andar)? Dahil ba sa sobrang init pa ang makina? Sira na rin kaya yung motor ng cooling fan ko? - maingay na sya compared before.
    Thanks nga pala sa lahat ng nagbigay ng advise sa akin.
    Oct 2003
    #23
    sa akin minsan ganun, weaponx. the aux fan turns on for quite a while pero nawawala rin (that is if i dont start the engine right away)..di ko naman napapansin and i have to point out that this RARELY happens..
    Dec 2003
    #24
    weaponx
    baka naman naka switch on aircon mo, iikot talaga ang fan ng condenser.
    now pag yun nag on ang Radiator fan ibig sabihin mainit ang tubig sa radiator mo, Normaly temperature triggered ang radiator fan.
    so kailangan mo hanapin ngayon kung naka recto ang rad fan mo o hindi, pag recta ang fans mo, tuloy tuloy ikot nya,
    Feb 2005
    #25
    Quote Originally Posted by zechs
    Same with me, bihira lang mangyari. But di naman sya ganon dati. Anyway, obserbahan ko, pag-naulit uli. I'll check if the fan will turn-off after a while.
    Thanks.
    Feb 2005
    #26
    Quote Originally Posted by Mojo
    weaponx
    Hi Mojo,
    It isn't the fan of the condenser. Aircon is off.
    So temperature triggered yung pag-on ng radiator fan when key is set to ON(II) position. Tama ba?
    Pwede kasing ngayon ko lang napansin kasi maingay na yung radiator fan. It may be true na baka sira na motor o kaya yung mismong fan. Surplus radiator fan/motor na kasi yung nakakabit. I was already thinking of buying a new set of fan.
    I believe hindi nakarekta yung rad fan ko kasi bihira lang sya mangyari.
    Thanks for the info.
    Oct 2003
    #27
    yup temp-triggered ang aux fan. usually after a while na naka-on na ang engine, the aux fan automatically turns on and turns off to help cool down the radiator.
    Feb 2005
    #28
    Hi Zechs,
    Yes, it's true when the engine is on. What I mean dun sa tanong ko kanina if same din ba kahit kapapatay pa lang ng makina after a long travel, then I turn the key to ON(II) position, (di ko pa start makina nito) na mag-on ang aux fan kung mainit na mainit o mataas pa ang temp.
    Pasensya na sa kakulitan. Newbie pa kasi ako sa tech matters ng sasakyan eh.
    Dito pa lang ako sa tsikot unti unting natututo.
Something turns on before Start of Engine!
